Question about Kenmore Washing Machines
My kenmore top load washer will not spin. It fills, agitates, drains, then wont spin, it will not spin on the first spin cycle, it will on the second cycle. The model number is 110. 20832 990.
It's likely just the lid switch is broke
Lid switchPART NUMBER: 3949238
Posted on Jul 06, 2013
  • Kenmore Master
  • 8,220 Answers
Try it in all the timer cycles. If it still does it then your transmission might need to be inspected. It is a simple design. Remove the agitator and then yank out the tranny. Remove the clutch and transmission cover. Inspect the main drive gear and the spin pawl beneath it.The main drive gear show in this 30 sec video is plastic (click on the link). The new gear comes with a matching pinion for around 75 bucks. More HERE
Posted on Apr 06, 2011
I have a kenmore washer model 110.22994. It fills with water but does not agitate. How do I start to identify the problem? The problem started after a friend loaded the machine with heavy jeans.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool / Kenmore service manual for top load, direct drive washers with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing to check is to try the washer on a different cycle.
Then make sure that it will drain and spin.
If it will work on a different cycle, the problem points to the timer.
If it still won't agitate and it WON'T drain or spin the problem points to the Lid Switch
If it will neither agitate, or spin but will drain, the problem points to the Motor Coupler.
Jan 09, 2010 | Kenmore 22982 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer
to answer your first problem,
if it wont stop filling, then the pressure switch is either defective,
or the hose that is attached to the drum to the pressure switch was either pulled out or had an opening either it breaks or it cracks.
that would not transfer the filling mode to agitate mode.
the second problem that it wont drain and spin now is another issue but might be resolve if you solve the first problem.
tnx 4 using fixya,
drcool
Aug 30, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
182 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
