Question about Dishwashers
I have a portable Sears dishwasher model # 66517769k600. It makes grinding noises when empying out the water, then stops. Sounds like maybe something is jaming the inpeller blades on the pump that removes the water as Water is left in dishwasher. It will restart in about 15 mins , run for 15 to 20 sec and stop again with same noises. What needs to be done to fix this issue? Approximate cost of part? Thanks in Advance, Chris
  • 3 more comments
  • Chris Apr 06, 2011
    no it is not a grinding metal to metal sound.
    Is the pump acessable from underneath?
    How much of the interior aSSEMBLY needs to be removed. if any?
  • Chris Apr 08, 2011
    Ok .I have determinrd that the problem is/are most likely 2 small pieces of broken plastic, (found a hard plastic item with 2 chips missing ,each about the size of a dime. ) I believe these are what are caught in the impeller. Can I remove the spray arm and other parts to work my waydown and get to the impelled from the inside of the dishwasher? The drain hose is not the problem. the motor is def. vibrating. Thanks, Chris
    I need a little more specifics. Are you saying to drop the motor from the underneath side?
    There are 5 plastic cams that apperar to allow this. What then? I would think this is sealed. How does that let me get to the impeller? Also the parts Diagram says I need a special tool to recenter the pump. True?
    Thanks Again
    Chris
  • Chris Apr 09, 2011
    It makes grinding noises when it starts,then it stops. I have determined the problem is/are 2 small pieces of hard plastic that broke off an item being washed. I believe they are jaming the pump impellar.
    The motor will run with lots of noise, then it will stop and will restart in about 15 mins , run for 15 to 20 sec and stop again with same noises.
    What needs to be done to fix this issue? Ie, How to remove enough of the parts and which ones to remove inorder to access the drain/impellar and to remove these 2 pieces of plastic? I have already removed and checked the drain hose.
    I need a fairly step by step answer
    Thanks in Advance,
    Chris
  • Chris Apr 10, 2011
    Thanks, is exactly what I was looking for!
  • Dishwashers Master
  • 1,902 Answers
Hello & Welcome to FixYa
It's a simple fix as the impeller needs replacement, will cost you around $20, please check this video on how its done:
Please get back to me if you have any other questions.
Kevin
Posted on Apr 09, 2011
  • 19,396 Answers
Hi.
First check and if needed replace the filter.
If the noise is grinding metal, then your diagnosis may be correct (cross finger the pump in question is the outlet pump. The main impeller pump is expensive). The blades inside the outlet drain pump are damaged and making noise. Before replacing the pump, clean the drain well, then access the pump, and remove blockage from pump hose if any. Blocked drain lines can make noise. You need to be sure that noise is coming from the pump.
Here related parts.
Here all parts and diagrams for your dishwasher.
Regards.
Ginko.
Posted on Apr 06, 2011
  • 1 more comment
  • Ginko
    Ginko Apr 06, 2011
    Hi.
    The ultra wash should have an access panel retained by screws at the bottom in front:
  • Ginko
    Ginko Apr 06, 2011
    About parts to be removed, there is not much to be removed. You are not going to replace the pump, that is fine. Remove the cover and you will see the hose going to the pump. Disconnect the hose, remove blockage, and be prepared with containers to remove water. Disconnect power cord or trip circuit breaker before starting.
  • Ginko
    Ginko Apr 08, 2011
    Hi.
    If possible I suggest working from underneath the dishwasher.I think that the bottom panel is secured to the side panels on this compact.
    Here the frame and panels exploded view. Click on this link, then click on the picture to enlarge.
    Regards.
    Ginko
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer makes grinding noise but isn't doing anything else
Remove the cap off the agitator, flip back the top of the console, remove any nuts keeping the tub in the console. There will be a clutch ring that needs to be replaced. I have an older top load washing machine. I agitates, fills, and drains, but it won't spin. It sounds like it is spinning, but it doesn't. It might be the coupling. That is a 3 piece kit that goes between the transmission and the motor. I found the directions how to do it over the internet, got the part and fixed it myself.
https://www.structuredsettlement-quotes.com/
Nov 08, 2013 | GE GSM1800NWW Spacemaker 18" Built-In...
We recently purchased a new pump for our frigidaire gld4355rf dishwasher. The old one started making grinding noises. When we moved the dishwasher it had leaked due to a failure of an interior seal. Our...
it could be a crinkle in the drain pipe or slight block, the pumps do make some sounds from time to time. it some time can even be the rubber grommets were the pump sits.
Jun 19, 2017 | Frigidaire GLD4355RF Dishwasher
Grinding noise when first starts running after filling with water
Do you know if your dishwasher has a built in disposal to grind up food particles that end up in the water? Could be a problem with that, or maybe with the pump.
Is water being moved about with the arms spinning.
I would call an appliance repair shop with your model # to find out what they think.
Feb 14, 2011 | GE 24 in. GLD5500L Built-in Dishwasher
Dishwasher makes grinding noise when running
Sounds like you have debris like broken glass in the chopper assembly of your sump assembly. Best of to call a Certified Repair Company such as Sears if you are not mechanically inclined.
Mar 20, 2010 | KitchenAid Dishwashers
Load grinding noise, like the engine is working too hard.
Most likely the motor/pump assembly is worn out and grinding. If the machine is less than five years old it is under warranty. If over five years old, the repair part alone is about $150 not including labor.
Apr 17, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
GE dishwasher model GLD4200 making a growling noise
I do not know of these machines but would say it sounds like bearings related to its rotating arm if it has to deal with water.
It would have a seal at the back before the bearings which has failed so water has leaked onto it causing rust to form in the bearing which builds up fuses the ball bearings together in clumps, make it hard to rotate so you get a grinding noise followed later by squeaks as things deteriorate.
So sadly it needs a service call out or it will grind to a halt, this happens say after a few days of non use letting the rust level build up.
You can use it but at some point it will not be able to rotate and it will just stop with some odd error message if it has that ability. Sorry for the answer.
Hope this helps...........
Apr 27, 2017 | GE GLD4200L Built-in Dishwasher
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Grinding Noise
you an remove lower access panel run d/w and nextime it makes the noise grab a flashlight and take a look under. sounds like a vibration issue( especially since you hit it nad it stops) perhaps your copper water line is rattling or your drain line is hitting motor causing noise
Feb 23, 2008 | Dishwashers
Dishwashers Logo
129 people viewed this question
Top Dishwashers Experts
