Question about Garden
23HP B& S Inetk on a MTD (Huskee) riding mower that I just bought to give to my daughter and Son-in-law. Runs fine the whole time when it is under load, but taking the load off to drive it to the shed, it starts popping. Not really a backfire, just popping. The couple I bought it from said they had a tune up a year or so and had the plugs, filters, blades etc replaced, and he adjusted the valves. I am wondering if you might think it could need a valve adjustment. A friend of mine who has worked on engines all his life, thinks it might be a fuel issue. It does seem to run a little better with the choke slightly pulled out. Thanks, Errol
  • 3 more comments
  • Errol01 Apr 06, 2011
    According to the couple I bought it from, this has been going on since right after they had it tuned up over a year ago. fuel filter has been changed, and I see no water in the new filter. Could it be some water build up in the fuel bowl on the carb?
    Would running something like "Heat" through it help if it is water?
    drained tank, replaced filter again, added 2 gal of non-alcohol regular, and 1/3 bottle of STP gas treatment. It is running now with mower engaged. Will run it for an hour or so before using it. Will see what happens over the long run.
    Thanks,
    Errol
  • Errol01 Apr 07, 2011
    Valve out of adjustment was my first thought, but I am used to working on large engines, not twin cylinders. I will check the adjustment as well as adding the STP which I did yesterday, and ran it for about 30 minutes, also drained the tank, and filled with non-alchol gasoline along with the STP. Will see what happens, but I will check the valve adjustment. Thanks for the ideas.
    Gas,
    My book shows the top valve on either side as the exhaust valve, and that the setting should be.009-.011, and the intakes at .004 to .006. Are those right?, and how do I rate your responses?
    Thanks,
    Errol
    President:
  • 2,187 Answers
It may be a fuel problem Inspect the fuel delivery if its constant and the quality of the fuel. It may be a bad fuel filter or the fuel tank may be dirty. Inspect also the fuel lines if it is in good shape and no dents or bends on it.
Other than that it could be the fuel mixture. The carb may need cleaning or you may have to adjust the fuel mixture.
Posted on Apr 08, 2011
    Brigadier General:
  • 4,736 Answers
Errol, from what you have described it sounds (literally) that the exhaust valves need adjusting. I suspect, that without adjusting them or having them adjusted, sometime very soon, the engine is going to backfire when it's being turned off and it won't start the next time. It will probably crank, but it won't start. ,you have the right tools and know what the gap should be, it's not really a DIY project.
Now, I'm not discounting what your friend suggested. Bad fuel or a clogged carb may be an issue. But, it will tie in with the other one I pointed out. Maybe your friend, who has worked on engines all his life can help you tighten and re-gap the exhaust valves.
Good luck to you. You're a good father and father--in-law, to make a purchase like this for them. I hope they appreciate it.
Posted on Apr 07, 2011
  • Rich Landrum Apr 07, 2011
    Yes, it could be water water buildup in the carb. But since it's been ongoing for over a year now, I doubt it. Rather than running HEET thru it, I'd use a good quality carb cleaner. But, I must warn you, if the backfiring continues, the exhaust valves will become unseated, if they aren't already.
    if you don't mind, I'd really appreciate you taking a moment to rate my responses to your questions. Thanks
    Sounds like a plan to me, Errol. Hope it works out for you. Exhaust valves can cause a problem.
    I know from own personal experience. Would appreciate it, if you rate my help and responses to you. Thanks.
  • 3,400 Answers
It almost sounds like condensation(water/moisture in fuel) and maybe a clogged or varnished fuel filter. Run a good fuel system cleaner through it and change fuel filter is where I'd start.
Posted on Apr 06, 2011
  • Mical Caterina
    Mical Caterina Apr 06, 2011
    Don't use HEAT, that will dissolve gaskets. Use STP gas treatment or any version of Isopropyl Alcohol fuel system cleaner. Besides moisture, it will dissolve any varnish build up.
Huskee Supreme (MTD body) loose steering, looks like some spacer or grommet is missing, but can't find in parts diagram
?l=mtd&p=76902073%5c0001&nd=0&z=30
OK THE PART YOU NEED IS PART # 37 PART # 941-0656A ITS CALLED A HEX FLANGE BEARING
Nov 03, 2012 | Mtd Garden
Mtd 42" riding mower rear drive belt keeps popping off pulley
Hi, check the idler pulley arm and return spring on that belt. Its most likely not pivoting freely allowing the belt to loosen when you operate the clutch, regards Phil.
Jun 10, 2012 | Mtd Garden
23hp briggs on huskee only runs with full choke>>>??????? any help??
Pull the plugs, reconnect spark wires, and holding plug against engine (to ground the shell) crank engine. Good spark both plugs? Reinstall them, and check the fuel system -- dirty fuel filter, or dirt in carburetor or lines.
Aug 01, 2010 | Garden
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
Huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Aug 15, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Drive train belt replacement. huskee, mtd.
there should be a diagram on the new belts package showing how it goes
Aug 13, 2009 | Mtd Garden
Huskee jerks while going forward
Go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Enter the brand (Huskee) and model number, not the one you listed, but the one under the seat... hit search and click on illustrated parts, then click on Mower Deck. That will show you the routing and belt number.
Jul 06, 2009 | Garden
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
