Question about Garden
Karcher k5.55 the problem is the motor pulses when switched on and the washer only gives about half presure when going
3 Suggested Answers
  • 92 Answers
SOURCE: trouble with Karcher Pressure washer
Dear Pgarciax,
It is important that you must have mentioned the model number of your Karcher. Just the same I can surely say that your machine's fault lies in the "SPILL VALVE"
When the gun is open and pressure is being produced, the spill valve is in a relaxed position. Also it has at the bottom a valve, which when pressure is produced it is closed. If this does not close due to dirt or corrosion, the pessure goes down. Now when you close the gun,pressure forces the spill valve down to close the electrical system. Now if the "o" rings of the spill valve are damaged, the machine will start going on and off while in stand-by. So if you know how to locate the Spill Valve, all one has to do is change it with a new one.
In some Karcher machines there are 2 spill valves. One regulates pressure and the other one is for switching off the machine when the gun is closed.
Low pressure could also be due to faulty suction or delivery valves. Most probably the suction valves.
But when saying that there are short interruptions while in stand by, I stick to the fact that the spill valve needs renewing.
Regards,
MG.
Posted on Nov 19, 2008
SOURCE: Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Posted on Mar 12, 2010
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
It's a Karcher presure washer K2.54, one and a half years old. Was working fine last time but when turned on now there is very little pressure through the hose and the water seems to be filling up inside...
this sounds like the seals may have been damaged inside the pump or that the water inlet/outlet could be damaged. If you take off the front cover (use a star bit screw driver) then run the pressure washer you will be able to see were it is leaking from and then you can get the right part to replace it.
Mar 16, 2011 | Karcher Garden
After sitting for several weeks, I plugged my electric 1500 PSI unit and nothing happened. Usually there is a pulse in the motor and it waits for the trigger to flow water to reinitialize the pump. ...
this Karcher unit have a termal overload in the motor but your problem can be cause by a pressure switch the shutt on and off the motor when you stop spraying.
Aug 15, 2010 | Karcher K2.26 Electric Power Washer
Pulsing when idle and when operating
I have the same Problem, there is a leak at a seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and if you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Jul 12, 2010 | Karcher K2.26 Electric Power Washer
My Karcher 2.99 starts and stops, (pulses) when th...
Is liquid leaking from the base, when the Pressure washer is on ?
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 21, 2010 | Karcher K2.26MR Electric Pressure Washer
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
Karcher B402 pressure washer Motor runs as soon as power supply connected, on/off switch does not seem to make a difference and no pressure at outlet? Was working fine, stopped for half an hour, came back...
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
Jun 22, 2009 | Garden
Loss of preasue and pulses in standby mode
Check the oil. This is what happens when it is low on oil with my pressure washer. Kind of a safety feature.
May 15, 2009 | Karcher Garden
A FRIEND HAS LENT ME THIS WASHER, BUT HAS T GOT A MANUAL
Best to run hose for a minute before connecting to machine to clear any debris from hose, plug hose to machine and pull trigger to run water through, plug into power and away you go, when trigger not pulled unit goes into bypass mode, it is advised to not leave in bypass for more than about 5 minutes, this model is light and can easly be over heated so I would advise to switch off at machine and run water through every 20 minutes to half an hour for at least a couple of minutes, after you have finised using unit, switch off at machine, disconect water and power then squeeze trigger to release pressure from pump.
Apr 20, 2009 | Garden
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
Garden Logo
1,193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
