Question about Panasonic KX-T7433B Corded Phone
Where can we find blank template to re-assign extensions. The template has 6 rows of 6 options. The bottom options are pre assigned as follows, Intecom, Conf., FWD/DND, Program, Pause and Transfer.
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Posted on Mar 24, 2009
Centernet
  • 38 Answers
SOURCE: FWD/DND light won't turn off on KX-T7633
Depending on how your system is programmed, you should be able to turn the light off by simply pressing the FWD/DND button. Otherwise it will require you to dial a "cancel code" which also can be different on various installations. You can try *7100, but that is just one popular code.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
cnavarro
  • 2460 Answers
SOURCE: Assign Extension Name
THIS MAY NOT APPLY TO YOUR SYSTEM SINCE THE U.S. VERSION TA IS NOT THE SAME.
From the System Manager's phone, go into programming and select program 604.
Posted on Oct 28, 2008
cnavarro
  • 2460 Answers
SOURCE: FWD/DND - PANASONIC KX-T7130
Don't laugh. Push the button and read the display. It will either unset DND or CF :-).
The 7100 command is part of the sequence to cancel those features on most phone systems and 790 or 79# will reset the extension. Of course it may be different if you have a TDA or TAW box (*7100) or a KX-T xxx10 system.
Carl
Posted on Nov 16, 2008
cnavarro
  • 2460 Answers
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Posted on Jan 21, 2009
KX-T7431 try to dial out and dispaly says CO Not assigned, I cannot answer calls either!!!! Hellllppppp
What has happened is that the CO1 CO2 etc buttons have not been programmed to dial the access code for an outside line. You can do this manually by dialling 9 then the number you wish to call. You need to enter the programing mode from the default extension usually EXTN 20 or 21. You need to go into the options and assign the digit 9 and a pause (P). The system will allow you to set different options such as if someone is on CO1 and another user dials 9 from another extension, the system will then assign the next free exchange line, again this must be programmed via the default extension. Let me know if you need further help.
Sep 04, 2013 | Panasonic KX-T7730 Corded Phone
Cannot configure extension on avaya ip 5620sw
Is this a Definity, Communication Manager or IP Office?
Press, HOLD, 5 6 4 6 3 3 (LOGOFF) #
If that doesnt work, try: MUTE, 5 6 4 6 3 3 (LOGOFF) #
Nov 27, 2012 | Avaya 5620SW IP Phone 700339815
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
How do I change the Name of the person at an extension on the Panasonic KX T7431
press the Program Button, then (**1234), and scroll counter-clockwise through the options with the volume circle. the option should say, "004 ext name set." to enter into that option to change, press the sp-phone button. continue pressing the sp-phone button until you find the extension number you would like to change. once you find it, press the transfer button and spell the designated name using the dial pad. For example, Mike (press 6 and use the volume circle to browse the letter you need from that assigned key- to get M) to continue spelling the name, continue using the dial pad and repeat to assign the designated letter. to store the name, press the "Auto Dial/Store" button and it will beep to confirm.
hope this helps, deanna
Jun 28, 2010 | Panasonic KX-T7431 Corded Phone
Why doesn't my printer let me print assignments like resumes etc???
You may have used a template to make a resume. I am assuming you use Microsoft word to do your assignment. If that is the case, you start with a blank sheet of paper. For example,If you would like to have rows and columns, click on table then insert rows or columns and use tab button to move from one column to other. Basically, in the absence of a template you need to do your own design of the page.
Even after that you need to check how the printer is going to print it. To do that, Click on file. Scroll down to print preview. Click on that. When the page opens it will show how exactly the printer is going to print. (You may notice some lines you had on the original document is missing in the new view) If what you see is not what you need, then make necessary changes in the original document. For example borders on table properties. Once done, come back to preview.
Jan 29, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
How to assign a name to an internal line extension? Phone is a 4412D+. Staff come and go and I need to know how to assign a name to the extension and how to delete names of staff that have left.
http://www.fixya.com/Unanswered.aspx?ctgid=123&__PAGED_rvUAnsw=6#divUnAnsHdr
If you download your manual above, there are numerous entries regarding extensions
Jan 06, 2010 | Avaya 4412D Corded Phone
Need to restore F1 word function in word 2003
  1. On the Tools menu, click Customize.
  2. Click Keyboard.
  3. Click Reset All.
Note: Reset All removes your customized shortcut key assignments and restores the original Microsoft Word shortcut key assignments in the selected template or document.
Nov 17, 2009 | Dell Latitude D505 Notebook
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
New to system, need to set up 3 voicmail exts.
Begin with what do you have for a voice mail? If it's a Panasonic brand, you log in as administrator (mailbox 999) and create the mailboxes. It is usually done at installation, unless your installer closed them down to prevent fraud. It's option 6 1 1 and you enter the mailbox you want to create. If it exists, it will tell you so, if not, it will create one. Then follow the prompts to assign an extension to the mailbox, and give it a name.
The extension user then dials the voice mail access code and creates greetings and a name and sets the password.
Carl
Oct 15, 2008 | Panasonic KX-T7731 Corded Phone
Compaq keyboard
You probably need to load the Compaq utility that assigns and activates the keys. Go to http://h18000.www1.hp.com/cpq_support.html
enter the model number of your compaq computer, and search the available downloads for the utility.
Nov 27, 2007 | Compaq Presario 5000 PC Desktop
Panasonic KX-T7433B Corded Phone Logo
250 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
