Question about Polar A3 Series 1902750 Wrist Watch
I have a polar a3 watch / hrm and tried to change the battery. I think I have every oriented correctly but it does not wake up with the new battery. Are there pictures available (say an exploded view of all the parts in the proper orientation?) to assist me in proper re-assembly? Thanks!
    Problem Solver:
  • 4 Answers
Polar A3 Watch Battery Replacement
Read all instructions first.
Once you have the back of the watch off, examine the watch and dry run the instructions in your mind. Prepare for trouble! So you can avoid it!
Work in a well lit, spacious area and NOT over a shag rug.
You\'ll need a set of jeweller\'s screwdrivers, with a couple of small philips (hex) heads and a large plate for itty bitty bits and pieces. And a Black Sharpie.
Carefully remove the back casing of the watch by removing the 4 screws. PLACE EACH INFURIATING LITTLE SCREW IN A SECURE PLACE OR SURE AS S&S, YOU WILL LOSE THEM!
TRUST ME...
Upon removing said back, you will see the battery and a half-moon shaped retaining clasp, which holds the battery in place. This clasp is narrow at one end and square at the other. You WILL also notice that each end of half-moon clasp (HMC) slips under the main metal retaining casing of the battery to hold the battery in place. Examine this carefully, and keep a mental picture of this in your mind. This is the end result that you must produce again.
Notice the orientation. Take a Black Sharpie and make a dot on the square end of the HMC and on the watch compartment, so as not to inadvertently switch the ends. (It won\'t install, but this is a nice way not to have to have a panic if you forget the orientation.)
Digital pictures are cheap. Take a picture if you\'re not the most gifted in do-it-yourself stuff. Learn from my mistakes, my young padewans!
In the half-moon clasp, you\'ll see a small circular opening at the narrowing end.
Insert the screw driver and GENTLY pry back on the screw driver, so as to warp the piece of metal--into a U shape--such that the end--where the hole that the screw driver is in--slips out from underneath the main metal casing.
BE VERY CAREFUL HERE!
THIS IS WHERE THE CURSING STARTS AFTER YOU HEAR THE QUIET "FO-ING!" AS IT FLICKS AWAY, NE\'ER TO BE SEEN AGAIN, IF YOU\'RE WORKING OVER A SHAG CARPET.
IF THIS OCCURS, SEARCH FRANTICALLY. GOOD LUCK.
For those of you who have managed to remove the one end of the half-moon clasp, gently pull the HMC, with the screwdriver in the hole, to remove it from the position.
Place HMC on plate with itty-bitty-screws.
There is a small circular indent on the edge of the battery compartment.
Place the screwdriver tip in this and gently pry up to remove the battery.
Replace the old battery, with the new one. (Set the old one aside, far aside. You think I\'m kidding? Trust me... It happens. For those of you who did not head my warning, you might want to start again! Especially those that didn\'t check to make sure the watch was running!)
Take the HMC, set it on top of the battery in the original orientation and with the screw driver, gently press down on the square end--compressing the HMC and battery--such that you are now able to slide it, the square clasp end, under the circular compartment metal lip, that the battery fits into. Excuse my dangling participle and grammar.
The other end--the narrow end--of the HMC should be sticking up.
Run through these steps in your mind to set up the best approach for yourself.
Orient the watch so you are comfortable working with it.
Insert the tip of the screwdriver end into the hole in the narrowing end of the HMC, and gently, press back on the screw driver, so as to warp the HMC, and...
The screw driver, in the hole, should provide enough friction that it doesn\'t slide in the hole. Do not insert the screw driver too far into the hole, or you will not be able to maneuver the narrow end of the HMC, guiding it with the screw driver, back under the lip of the compartment, as it was originally.
... slide the narrow end under the lip.
If all has gone well, you should be able to turn your watch over and it will be displaying...
Gobbledy-gook or nothing at all! And you\'re screwed!
Not so fast my young padewans!
Most likely, you are seeing gobbledy-gook.
This is good. It means the watch battery swap has worked.
Turn the watch back over and you will see a itty-bitty copper finger, protruding from the battery compartment edge, out over the battery.
Gently press down on this, so it touches the batter, using the screwing driver, to reset the watch.
Turn the watch over and it should be displaying the basic reset display, flashing 12HR.
If not, the battery is not seated properly.
Remove the battery and begin again.
Check to make sure you have a new fresh battery.
Otherwise, carefully install the back cover with the itty-bitty screws. (IBS)
When screwing in the IBS do not speed them in, by rolling the screw driver in your fingers against your palm.
Insert the screw, (I use fingers, you may want to use tweezers.) and place the screw driver into the head of IBS and orient the screw to a perpendicular position, then turn the screw counter-clockwise in order to set the threads, then turn 1/2 turns, clock-wise, reseating your fingers, to provide firm pressure when screwing in the IBS.
Start in one corner, and screw in the screw so that it is just loose to the case. Then do the other, opposite corner similarly, then the corner to the side (pick one...) then the opposite corner. There\'s only one left at this point...
Make sure the case is seated properly, and that you\'re satisfied with everything (No spare parts kicking around!) and repeat the proceedure, tightening the screws in the criss-cross pattern.
Reset the watch as per instructions for time and date and knock yourself out.
SweetDoug
Posted on Mar 09, 2013
  • 1 more comment
  • Scott Hertzog
    Scott Hertzog Nov 02, 2013
    great tips - here are some pics for clarity - make sure the gasket lines up with its 'key';
  • Scott Hertzog
    I'd seen someone had managed to pop out that brass piece in the upper pic.
  • Scott Hertzog
    p.s. - it being Halloween season - I scored 2 CR2032 for $1 in 'tea' lights ;)
    Guru:
  • 347 Answers
Unfortunately there are no exploded views for this watch as they are not intended to be user serviceable. The A-Series needs to be sent in too an authorized Polar Service center for battery replacement and repairs. Much can go wrong with these mini computers as you are finding out, and not re-pressurizing the watch will lead to problems in the future from sweat vapor and other water vapor getting inside.
I have links in my tips and tricks page for manuals and service centers or you can click the link above.
Posted on Apr 06, 2011
HOW DO I SET TIME AND DATE ON MY POLAR AXN500?
For all those who lost their Polar Heart Rate Monitor manuals. Follow this link, fill in the details and get manual. Plenty of other Polar product info and support on this site.http://www.polar.fi/en/support/downloads?product=&category=User+manuals
Aug 26, 2012 | Polar AXN500 Heart Rate Monitor Watch HRM...
Professional battery installation, doesn't turn on, is there a power on button? Or do I need to take it back and have them try again?
There are only a few Authorized Polar Service Centers. If you did not take it to one of these (which provide a 90 day warranty) they may have broken something or put in the wrong battery.
Polar and other HRM's are mini computers and actually quite delicate inside, they are not normal watches and while many watch repair places profess to be able to fix them, more often than not they cause a new problem. They are also repressurized with a special machine to keep them watertight, your watch is most certainly not watertight anymore and will eventually cause yoiu problems.
Too answer your question, no power on switch, if the battery install was good you would see a display. Take the watch back to the shop, and if they can not fix it, send it to Polar and then have the shop reimburse you for the repair. Polar will be happy to send them a detailed and Itemized account of what they had to fix.
Dec 03, 2010 | Polar FT40 Heart Rate Monitor Watch
Cleaning polar s725 watch/hrm
"Gunk" is definately not good in any watch. If it got in there because your watch is not properly sealed then you would need to clean it out and get it properly sealed up again. Proper lubrication is necessary, but "gunk" should not be in there.
Nov 18, 2009 | Polar S-725 Wrist Watch
How do I change the battery?
Someone posted a link on how to change the batter on an F11. If it's not longer under warranty or you just don't want to bother with sending it back and the extra costs, you could follow this: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Jun 10, 2009 | Polar M32 Heart Rate Monitor Watch
How to reset the heart rate monitor information after a workout
Can this be any help?:
http://assets.timex.com/manuals/?timexBrand=core
Mar 23, 2009 | Timex T5E921 Ironman Triathlon Sports 30...
Which way round does the battery go in a Polar FS1 HRM watch?
Battry must go - (minus) into the movement and +(plus) facing up. As battery replacement must be done with watch upside down, you must see the +(plus) on battery when it is inserted into the movement and the fit the contact over it.
Do not forget to rate, please.
Mar 11, 2009 | Polar FS1 Unisex Heart Rate Monitor Watch
I have a problem changing the battery of my polar HRM watch.
Here is the link:
http://www.polarelectro.co.uk/uk-en/support
As this is direct link to Polar (UK), I will accept FixYa rating only, even if you will not be able to find what you are looking for.
If you are not happy with that- don't blame me (I'm not the owner of this site) and did my best to find a solution for you.
Not happy-do not rate, please.
Jan 24, 2009 | Polar M32 Heart Rate Monitor Watch
Can`t pair Garmin Forerunner 50 with footpod
I've been having the same problem. I couldn't pair my footpod, but my heart rate monitor was working. I've only had the 50 for about eight weeks.
I reset the watch, holding view mode and Start/Stop at the same time.
This didn't do any good.
I swapped the battery in the HRM with that in the foot pod. The foot pod synched the HRM didn't.
Solution duff battery. I'd change yours it will probably do the trick.
Hope it helps
John-Paul ( AKA OldGreyWizard)
Jan 10, 2009 | Garmin Forerunner 50
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Polar A3 Series 1902750 Wrist Watch Logo
2,165 people viewed this question
Top Polar Watches Experts
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
