Question about Gaggia Classic Espresso Machine
Very slow drip of water coming out. Takes longer and longer to make a cup of espresso.
    President:
  • 1,618 Answers
Remove the screw and shower screen, make sure screen is not blocked with coffee oils.
Posted on Sep 23, 2011
Water heats up.slow drip comes through and fills only 1/4 cup.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 27, 2011 | Keurig B60 Coffee Maker
How does the pot make strong or reg. coffee by pressing a botton not adding coffee amount ?
By pressing the button for "stronger" coffee, it slows down the rate at which the water enters the grounds. This allows the water to set in the grounds longer and therefore can make the coffee a bit stronger. This is why on some pots when there is a 4 cup setting used, it takes longer for the coffee to be made. With such a small amount of coffee, it should go thru more slowly to get the same result.
Mar 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Very slow output to fill cup
You will need to Descale the Machines. Most likely calcium bulidup inside machine.
Jan 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Very slow water output
Open door of machine & take Brew head out. You will see a cylinder shaped part which is black with an orange washer half-way down it. Look underneath this cylinder and you will see a steel disk,(which may look black) this is the filtre. Now look above the cylinder and you will see a turn knob, turn anti-clockwise untill the disk comes free. Hold the disk up to the light and you will see the minute perferations which are all clogged with coffee grounds, give this a thorough washing under running hot water ,( use the brush provided with your machine to push the grounds through. You will also need to blow through these holes very hard and often untill you can see that they are cleared. This should be done after about every 15 cups made. I got this info. from the Gaggia engineer and it works!! Good luck.
Jan 12, 2009 | Gaggia Titanium Espresso Machine
Can't get a full cup of coffee
First, you should not be using your espresso machine as an american coffee maker. It puts way too much pressure on the components of the machine. The standard cartridges are made to do 1.5 - 3.0 ounces of espresso. should you want to make a longer cup of coffee you need to get the aroma point gran caffe cartridges, lavazza code 427. this will enable you too get the longer cup of coffee without putting the added stress on your machine. Also it sounds like your machine mighy have a problem with the volumetric device. are you getting water in the capsule ejection drawer? should you want service you should call 781-393-2929. we are an authorized lavazza distributor and repair center.
Oct 09, 2008 | Lavazza Espresso Point Capsule Machine
Royal Professional machine
try to set the grinder to grind little more coarse, you have to make 2-3 cup to get the new settings to work.
To get off the ventilate you have to press the button for hot water and make a cup of water.
Hope this will help you.
/Mirran
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Gaggia Classic Espresso Machine Logo
212 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
