I have a problem regarding may pc...I also want to know what is the possible solution to made of it..Here's the problem..every time I open my Ups my cpu automatic on even I don't push the On button in cpu and no beep you would hear and there's no display display in monitor.. I tried to clean memory,video card and other parts of computer but it's same result..but the fan of processor is running..hoep somebody would help me ASAP thanks a lot!!
  • yadayada
    yadayada Apr 06, 2011
    I would suggest you try our livve chat service for this problem for a faster answer. Thanks
  • Daniel Wakefield
    Daniel Wakefield Apr 06, 2011
    What kind of computer is it? Does it do the same thing if you plug it straight into the wall?
  • 60 Answers
This is a possible hardware failure. You can try these steps:
1. Try resetting the bios to factory settings using the the jumper.(check your motherboard manual for that).
2. Remove the memory, then turn on the pc. If you do not hear any beeps, it is not a memory failure.
3. Disconnect all cables connected to the motherboard except the power cable for your motherboard.
Turn on the pc and check if there is a beep or video. If it still does not work it could be your motherboard or processor.
Posted on Apr 07, 2011
  • enigma pulp Apr 11, 2011
    I try to put it processor in my other pc and it works.. I also try to not input a memory on it and there's a beep
  • Dick Tulagan Apr 17, 2011
    I see. Is it a long beep? if it is it indicates that the motherboard is working. Try cleaning the memory contacts with a pencil eraser. You can also try using another memory.
My APC ups doesn't power on
If your APC UPS is new but was stored unused for awhile, the battery may have discharged completely. You may find a comparatively less expensive and less time consuming solution is replacement.
Feb 22, 2013 | APC Smart-UPS® XL 2200VA (SUA2200RMXLI3U)...
Hi! Per our UPS problem is when open 3 or 4 hours, then auto Off the UPS. please let me know what the problem. And i need to change the PCB board or just repair the PCB board? Thanks Regards
If you unplug the unit and it powers your PC for 3 or 4 hours then turns off, it is because the batteries are empty and this is normal. If it is plugged-in with power and shuts itself off after a few hours, then the battery cells may be in need of replacing. You can purcase an inexpensive replacement battery here: http://www.upsforless.com/browseproducts/Powercom-Replacement-Battery-Kit-BNT-500A-BNT-500AP-BNT-600AP-BNT-800AP-KIN-425CSU-KIN-625CS.HTML
Dec 01, 2010 | Powercom BNT-600AP (bnt600ap) UPS System
Keeps beeping every 2 seconds...
It sounds like its possible your battery is discharged or close to the end of its life, and needs to be replaced, but without better details its impossible to know the exact cause.
A user manual for your ES 650 is available here: http://www.refurbups.com/KB-M-Backups
Mar 28, 2010 | APC BE650BB BACK-UPS ES USB 650VA WITH...
Problems with APC Smart-UPS 1000VA UPS System
Whenever you get problem with UPS call the concern technician for repair, you never try do any thing in UPS if you doesn't know about it.
Regards
Ashly
Feb 04, 2010 | APC Smart-UPS 1000VA UPS System
Problem with APC Pro 420
If the unit works ok on mains power, then it is the usually the batteries causing this, New battery i think you need.
Sep 17, 2009 | APC Back-UPS Pro 650 UPS System
Pc is restarting every 3 - 4 minutes , even though it is connected directly without a UPS(it is free from viruses )
i am a pc tech and of course i can only listen to you and give advice and things to do to determine the source of the issue, i am first thinking overheating,dirty fan blades and a cloged cpu heatsink will surely cause this kind of problem,? is the pc new/old, is it clean or not,and also what is the make and model and specs , ram, processor, hd gb, and if possible open the side of it and look for lots of dust and look for the fan and be sure it is working there will be atleast 2 one for the inside box and one on the motherboard(the large circuitboard) see if they are working and if they are clean . get back to me and i will respond asap Robert Alan
Jun 01, 2009 | HP Computers & Internet
Nexxtech 1000VA UPS
hi, check the battery and clean the connections with a little file or other tool. then try it again, the battery can dry out through time. hope this helps you, good luck! glen
Jan 28, 2009 | Computers & Internet
Powerware 9330
your problem could be related to a dispay board or possible CSB board.
Sep 24, 2008 | Powerware Invensys 9330 Model 40 UPS...
Ups randomly shuts off
Hi, Could be anything but chances are it's the battery. It's very rare (but still happens) for the electronics of a UPS to be faulty. Try leaving the UPS powered on but without any load (PC, monitor, printer off) for a few hours or better still overnight. Try it again and observe if the random shut off occur. If yes, then it is time for a replacement battery. At certain instances, it may be that the UPS is working too much (overloaded), try just running the CPU to the UPS and the monitor directly connected to the mains. Hope this be of help/idea. post back how things are or should you need further information. Good luck and kind regards.
Aug 28, 2007 | TriPro Power (POW-1000AS) UPS System
Keeps making a beeping noise
Hi, if the unit is fairly new, you may want to claim warranty check or replacement. If it has been used for some time, it may be that: 1) the battery is dying, 2) not getting enough charge or 3) too much load. For 1, battery replacement might be required. Care should be taken since this requires opening the enclosure, removing the old battery (might have acid leaks) and replacing with a new one. For 2), any competent techncian could diagnose and repair. For 3) try removing all other loads to the UPS and just run the PC with the monitor and see if the problem still exist. Hope this works for you and please let me know how things trun up. Regards.
Apr 09, 2007 | Powerware PowerRite Plus UPS System
Computers & Internet Logo
David Payne
David Payne
