Which of the 3 dispensers does the soap powder and rinse go in for the Bosch WFD2473
  • 3,289 Answers
You can read the manual here.
In short page 15 describes the chambers as follows:
  • The chamber marked "I" is the prewash detergent.
  • The chamber marked "II" is the main wash detergent.
  • The chamber marked with a flower like icon is the fabric softener.
Page 14 describes how to prepare for your first wash by running it without clothes for the very first time to remove water left inside from the factory during testing. Do not skip this important step! You only have to do this once.
I hope this helps & good luck! Please rate my reply. Thank you.
Posted on Apr 06, 2011
Testimonial: "this was so helpful and 'to the point' whereas other web sites gave me a roundabout course and couldn't even print the text. thank you"
Tip
The #6part is attached and not broken so I went to the second idea and tighten...
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
on Mar 02, 2011 | Stoves 27 in. DW60 Built-in Dishwasher
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Bosch #SHU9955 Integra dishwasher for the last three uses, the soap dispenser door was open with the powder soap caked in the lowest one half of the pocket dispenser. The dispenser door locked and unlocked...
The problem was evident during short cycle (primary cycle used) and changing to regular cycle used and back to short cycle seems to have corrected problem.
Oct 09, 2008 | Bosch Dishwashers
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Soap dispenser
There is a screw cap on the back wall of the dishwasher,unscrew the cap and place your rinse agent in there.I groove on the door is for your dishwasher powder
Apr 09, 2008 | Equator 20 in. CD 400 Compact Dishwasher
Bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
Apr 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing Machines Logo
229 people viewed this question
Top Washing Machines Experts
