Question about Samsung SyncMaster 753S 17" CRT Monitor
Samsung 753s monitor not showing red color
Plz help blurd
Help me! My computer is blinding red colour. My monitor is samsung syncmaster 753s 17" crt
Posted on Dec 04, 2008
Hi
There are two possible causes of no red color on a monitor like the 753s the first one being that the red wire in your signal cable is damaged or your video pre amplifier or amplifier has gone bad but since the other colors (green and blue) are ok then 1 would suspect a dry join on the video amplifier's pins or on the red signal path also an open resistor on the red signal path may be causing the prob
good luck
Posted on Oct 14, 2008
Width problem. screen cuts from both the sides
Posted on Aug 06, 2008
The number of FBT used in syncmaster753s /aq17ls7l/xtp
my color monitor is Samsung sync master 753s model
model code - AQ17LS7L/XTP
THE EHT [FBT] LABEL IS MISSING IN PLS SEND THE NUMBER
OF FBT & ITS PINS DETAILS USED IN FUNCTION OF CKT
Mar 05, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
How can i replace the red color driver on a samsung tv
if this is a crt computer monitor and the red has gone out it could be a bad cable if itsthe monitor throw it away and get a new one.
Mar 05, 2012 | Samsung SyncMaster 753S 17" CRT Monitor
My smasung monitor sync master 753 vga connector broken, what is color scheme for new connector
Colour scheme to re wire is as follows...
Pin Name Function 1
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Hope this helps!!
Jul 19, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Use the monitor then only blue and violet color show not show all colors
it is a problem of connection loose in board parts of monitor. it is called colar fade . it is repair by eletronic technican only. thanks
Nov 11, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Hello My PC monitor/CRT 17 inch. not getting
check the signal cable bend it in on condition and look what difference in color occurs if so then replace the cable if not that fault then ther is a dry solder on the base of monitor find out and clear it
Apr 05, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
RED COLOR IS OFF. ONLY BLUE AND YELLOW. TRIED DEGAUSS ETC.
was there any sort of magnet around the monitor this ofter causes color problems with some monitors.check you cable that connects the monitor to you conputer if it is bent.
Jul 17, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Cable color codes for samsung syncmaster 753s
I want to fix new vga connnector on my smsung syncmaster 753s monitor and i am confused with colour coding please help me
Mar 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Check vga cable (check vga port pins continuity with its wire inside monitor on video section that is placed on crt neck)If it is ok then check transistors in this section.
Hope this solution works
Jun 16, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Pls tell me how to open monitor for repair
Protocol Internet Caf'e
AL SALAMAH ST. JEDDAH
I also opened the cover of monitor but its really hard because the two clips hold it tight from the top of monitor. First I open the 2 screws at the back. Then you have to hold the cover very strong and its strongly to left and right like you are ripping it till and the cover gets free from the clips at left and right parts.Than when you look at the top of monitor, you will see little holes at the left and right sides of monitor. you will have to free them with a screwdriver. ( its mostly possible that there will remains some track:) i have 40 samsung monitor here in my cafe so plz guide me to open the cover of monitor. call me my no. 0564993626
May 14, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
357 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
