Question about Panasonic Televison & Video
I get a blue screen on my TV that says to clean the filter. wher is it located and what are the steps to do it
    Top Expert:
  • Panasonic Master
  • 75,289 Answers
Hello
What is the model number of your Panasonic Projection TV? Send it to me by Fixya. OK.
Posted on Apr 06, 2011
Wher is the capacitor located for the 46 westinghouse led tv
There are many capacitors in the TV and which one are you trying to locate?
Jul 31, 2012 | Westinghouse Televison & Video
Sony KP-57WS5610 Blue light will not converge the blue is offset from everything else on the screen so its like a blue shadow Any ideas on whats wrong
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 20, 2012 | Sony KP-57HW40 57" Rear Projection...
The TV keeps shutting down due to over heating. Is there something that needs to be cleaned?
Yes you need to clean the AIR FILTER located in TV.
Please follow the steps below to clean it.
1. Turn the television off and unplug the AC cord.
2. Locate the dust filter on the left side panel of the TV.
3. Using a phillips screwdriver, remove the two screws that hold the dust filter cover in place.
4. Remove the filter cover, set it and the screws aside.
5. Carefully remove the filter from the TV.
6. Clean the filter material by dusting with a lint-free cloth.
7. If the filter is soiled, you can rinse it with water. Do not use detergents or soap on the filter.
8. Completely air dry the filter before placing it back into the TV.
9. Replace the filter cover and secure with the screws.
For showing location i have attached a image.
Thanx
Jul 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Just bought 2005 chrysler pacifica. need to know where oil plug is.what size wrench for oil plug.wher oil filter is . is there any special thing i need to know.
I recommend VERY Highly that you get the Haynes Repair manual on the vehicle. It will provide Step by step instructions for basic stuff like Oil Changes and Tune Ups and the intervals for these. As for you question. The oil Drain plug is located on teh oil pan at the bottom of the vehicle, The oil Filter is located on the Firewall side of the engine, and other than understanding how to properly install an oil Filter and to use the correct oil there isn't much to it. Oh, the oil drain plug should be a 13 or 14 mm.
Jun 22, 2010 | 2007 GMC Yukon
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
A screen comes up and says time to clean air filter, Where is the air filter located?
I just experienced the exact same thing. The tv will shut off if it gets too hot, and a clogged air filter will make it too hot. My tv is still under warranty, but I watched the technician do it. He removed the front and back part of the tv. He got down to the bulb enclosure in the rear of the tv, which is where the filter is located. He used my dirt devil and a brush to clean out the filter and the whole general back of the exposed tv. The he put all the pieces back on the front and back of the tv. Hope that helps!
Feb 23, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Green screen
inside the light engine there is a red a green and a blue glass color filter.The heat from the lamp causes the color to burn off the glass.You need new filters .One is red one is blue and one is green.The lcd itself doesnt make the color,it is a black and white device.The colr comes from light shining through colored glass
Nov 11, 2009 | Hitachi 42V715 Rear Projection Television
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hotpoint wd860 filter
Access to the filter is by removing the rear lower panel of washer.
Locate the large black hose on right and remove clip and hose. watch out for water in the hose.
Remove filter and clean Refit filter and hose, securely fasten the hose and test for leaks.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Washing Machines
Televison & Video Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
