Epson Artisan 810 I had a paper jam notification. the paper was removed and turned on the unit. I heard a clunk then a grinding sound and an paper jam error message is noticed. Do I need a hammer?
SOURCE: Epson Artisan 800...adf keeps saying paper jam,
ADF Motor Assembly has gears which crack. Replacement of ADF Motor Assembly normally required. Compass Micro Inc sells this part. Part #: 2132225.
Posted on Jul 30, 2011
SOURCE: I have a epson artisan 800 I'm tring to fax from
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Posted on Mar 31, 2010
  • 17 Answers
SOURCE: Where/how do you load a CD for printing directly onto CD?
There is a special tray that you are able to slide out when you open the front. Take a look at this picture: http://www.blogcdn.com/www.gadling.com/media/2009/11/img_0204-[gadling-bumper].jpg
Posted on May 29, 2010
Testimonial: "Yes it was helpful. Great picture. Found the CD eject button after I sent request, but thanks for prompt response. Hitter"
  • 567 Answers
SOURCE: I have an Epson Artisan
Hi you should clean the print head and you need to take out the cartridge and pay close attention as you put it back into the printer because it may not be fitted in place properly.
Posted on Aug 08, 2010
SOURCE: My Artisan 810 ADF gets
Here are the two steps I used myself to solve this:
1. Complete your online registration with Epson
2. Call Epson tech support about the ADF jams. You may have to spend an hour going through various troubleshooting steps with them.
They simply sent me a replacement printer. This is cheaper for Epson than trying to actually fix the problem!
Posted on Nov 02, 2010
Printer Paper Jam
Look in the user manual first. If no help there Google with pointed info. The item model number and other pertinent info
May 06, 2015 | Used Epson Artisan 810 All In-1 Wifi...
A problem with epson artisan 810
  1. Turn the printer off, then disconnect the power and the interface cable. Open the cover and check for any torn or jammed paper and remove it.
  2. Reconnect the power cable and turn the printer back on.
  3. Press the Copy button and see if the unit responds.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the problem persists, an unknown printer error has occurred. The printer may require service.
Sep 08, 2014 | Epson Artisan 810 AllInOne InkJet Printer
Epson 810 printer
It seems you have Eprom malfunction there.
You can flash its Eprom with its new Eprom file or just replace its Eprom chip and everything will back as normal. This is a common problem for this printer especially L series.
This type of printer often showing paper jam while there is no a single paper in its tray and the paper's sensor still working fine.
Hope this will answer your question.
Sep 14, 2017 | Epson Artisan 810 All-in-One Color Inkjet...
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Feb 13, 2014 | Epson Artisan 835 Wireless All-in-One...
My Epson Artisan 810 is blinking (power botton and screen). It is showing an errormsg that says "a printer error has occurred..." I have called Epson, after a long list of troubleshooting items...
I had a similar problem. It turned out that something was jammed in the machine, and the CD tray had slipped out of place. Unplug the machine and check the path of the CD tray. Make sure that there isn't anything in the way. Don't force anything. I also had a problem where it was printing a dvd and it disappeared. It had slid part way into the back. It was jammed in there for several months before it caused an issue. The repair person, just removed the back part of machine by pushing the tabs and removed the stuck dvd.
Jun 20, 2011 | Epson Artisan 800 All-In-One InkJet...
My epson 710 artisan gives an error message that there is a paper jam or is out of paper, when I try to print a photo, it feeds through 2 blank 4*6 photo papers. There is NO paper jam when I check it, and...
Hello, Your printer makes a "grinding sound". This is usually due to two things:
1. A dirty printhead rail. It is either ink residue or dry. Try gently cleaning it with some water.
2. Paper pick up roller(s) not picking up. Clean them with a damp terry cloth towel or a multi-purpose cleaner.
If you have unable to fix it please contact me at 1800-204-4427. I can help you out.
Good luck!!
Jul 24, 2017 | Epson Artisan 710 AllInOne InkJet Printer
My Artisan 810 ADF gets jam error. There is no paper there. The motor just whirls and then gives ADF jam error. My 810 is near new, less than 300 sheets printed, less than 100 scanned using...
Just fixed my problem today. It was the ADF assembly motor. The spur gear had cracked open where it can no longer grip tightly to the center rod when the motor spins. I bought a new motor assembly from CompassMicro for the total amount of $23 and my printer is back in running order like normal again. Beats taking it to a repair center and get ripped!
Sep 10, 2010 | Epson Artisan 800 All-In-One InkJet...
My artisan 700 keeps pilling in multiple sheets and then jams.
hi there, il be glad to assist you.
If multiple pages feed at once, remove the paper from the tray, fan the edges to separate the sheets, then reload it. if Paper Jams Inside the Artisan 700 Series: Open the scanner. Remove the paper as shown, including any torn pieces. Squeeze the hooks and remove the cover inside the Artisan 700 Series. Remove the paper as shown, including any torn pieces Reattach the cover. Close the scanner. if after doing all of these still same issue persists, if the issue persists, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
Feb 16, 2010 | Epson Artisan 700 InkJet Printer
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
515 people viewed this question
k24674
jasbo
jasbo
