Question about Kenmore 600 7962 Dryer
Dryer runs but will not get hot - Kenmore 600 7962 Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 07, 2011
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
There is a burned odor when drying my clothes. How do I get lint from inside the dryer out if this is a problem
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 20, 2011 | Miele Novotronic T1515A Electric Dryer
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
heatman101
Aug 14, 2011 | Dryers
Clothes seem to get too hot
The cycling or operating thermostat is often the problem when a dryer runs too hot, but there are also other things that can make it run hot also.
Clothes Dryer getting too hot
heatman101
Aug 13, 2011 | Maytag Dryers
Dryer was running very hot and now there is no heat
heatman101
Aug 08, 2011 | Amana DLE330RAW Electric Dryer
My dryer is running hot but doesn't dry the
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
My dryer runs for about 10-20 minutes then shuts off because it must be overheating. After it cools down I can run it again. Is that an element problem?
heatman101
Aug 01, 2011 | Kenmore Dryers
When the dryer is running top of dryer where controls is hot to the touch
heatman101
Jul 29, 2011 | Hotpoint NVL333EY Electric Dryer
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
Dryer runs hot, and clothes are really wrinkled
heatman101
May 07, 2011 | Frigidaire Electric Dryer
Kenmore 600 7962 Dryer Logo
310 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
