Question about Bose On-Ear Headphones
The cable to the head phones has been cut can this be repaired?
  • 508 Answers
It depends where the cut is. If it is right near an earpiece, you may be able to resolder the remaining length to it, removing the cut part. Just remember the wiring layout (from the cable to earpiece) since these are STEREO headphones - and re-do it. Should work if you are careful.
If the cut is toward the plug end, and the plug is a sealed type, it will need to be replaced with a new one - available from electronics shops for a dollar or so each. Make sure you obtain a STEREO plug of the same size as the original.
If the cut is in the middle of the cable, you may be able to get away with 'splicing' the cable together - remember to insulate the wiring within it when doing this so as not to short out the LEFT and RIGHT to ground (3 wires in stereo headphones - left, right and ground).
If it proves too difficult for you, or cannot be repaired, consider replacing the headphones - as they are cheap enough to buy new.
Posted on Apr 09, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Yes it can be repaired
if the cable its cut in the middle just need to the to parts together with a knot
if calbe its cut from the joint with the headphone they need to be soldered
Posted on Apr 06, 2011
My v2 headphones stopped working there is nothing visibly wrong with them what happened? These were my grandpas so I really want them to work again
The wires in the cable are the weak point, they can break and you cant see the break, the head phones then don't work. Depending on who makes them, the repair could be difficult to perform. If the head phones are sealed plastic, they are hard to open to check the cable and change it.
Oct 08, 2016 | Audio Players & Recorders
My headphones have stopped working. I cannot hear sound from them at all, even though I haven't been using them much. It's model MDR-EX71SL and I bought them less than 9 months ago.
Have you tried them in another audio source. Head phone wires like to break at the strain relief of the main plug. Try moving the cord on the plug side of the phones. If it cuts in and out its time for a new set. Head phone wires are difficult to repair and it may be more trouble then its worth.
Oct 10, 2009 | Sony MDR-EX71SL Consumer Headphones
Display screen for ma 3230 phone
It is repairable but you need a microscope to inspect the solderings and there is alvays a risk off the data cable to bent and cut again near the solderings.
The soldering needs some experiense and right tools,
but the issue was "is it repairable?"
The solution is "YES" it is repairable.
This is your solution! Please vote!
Sep 21, 2009 | Nokia 3230
Stihl fs 45 trouble getting the cutting head to engage
repair shop shortened shaft just a touch to take up slack in drive cable
Aug 02, 2009 | Garden
How do you install a speedometer cable repair kit???
Install from the head down, placing the end with the brass stop on it at the head end. If you feel lots of resistance when pushing it through, the cable housing may be torn up. When you get it through cut off any excess so that it can easily be placed in drive gear end. Use chain and bar oil on new cable...I've found it works longer and better than anything else.
Jul 30, 2009 | 1989 Ford F 150
Audio cuttin out on my CDJ 800
Do you mean the RCA connection (red/white) on the rear of the unit? If so, then yes, more than likely it might have come loose, or damaged. If your comfortable opening it up, you can attempt to repair yourself. Otherwise, I would suggest taking it to a service professional.
Have you tried a different set of cables?
Always remember, whenever removing your cables, you want to grab the cables by the head of the connection, and never by the actual cable itself - you also don't want to yank your cables loose - this is usually what causes these sorts of connection problems.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 23, 2009 | Pioneer CDJ-800 Turntable
I have a porter cable fr350A round head framming nailer and when i connect the air it just comes out the top it goes strait thru,it seems like the trigger is on all the time.
I have worked on many fr350 nailers with the problem that you are describing. The fix is usually simple. I just remove the head and pop out the headvalve by using an air nozzle on the small port drilled into the mating surface. Be carefull because the headvalve could pop-out with force. Clean all surfaces and use silicone paste to lube the orings and the surface of the head where orings contact. Check for cut orings or defective upper bumper (cracks or cuts). Also look for small scratches with magnifying lens on the surface where orings contact. Sand with very fine paper (300 grit). Re-assemble and you should be good to go. Silicone paste is sold at Lowes in the plumbing department. It is used to lube orings in faucets. Parts are available at www.toolpartsdirect.com
Good Luck on your repair and email if you have questions.
Mar 20, 2009 | Porter Cable Cable No. FR350A Rnd Head...
Cut cord on sony MDR XD100 head phones
Check out my blog that contains information on headphone cable problems.
Real Life And Real Charts
Oct 14, 2017 | Sennheiser HDR 120 Consumer Headphones
Left headphone does not work properly
Based on your post/description, it would seem that the cable of your head phone developed an open circuit somewhere. I would assume it is pretty near the headset itself. On most occasion, it is at the very entry point where the cable goes into the headset.
Normal repair would involve opening the side casing where the cable enters the headset, cutting the cable about 3 inches from entry point, strip exposing the three or 4 wires and reconnecting inside the stripped ends. Effectively what you have done is trim the cable a bit shorter eliminating hopefully the intermittent section.
Hope this be of help/idea, Post back how things turned out or should you need additional information.
Good l;uck and kind regards.
Oct 27, 2007 | Logitech 350 (980374-0914) Headset
Bose On-Ear Headphones Logo
188 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
