Engine oil is getting into the radiator on 1996 saturn
    Brigadier General:
  • 4,736 Answers
The connection from the oil line into the radiator has failed. Sometimes it can be repaired, but it's best to replace the radiator entirely. As it has become contaminated, as has the heater core. I can tell you this ... Saturn's are a bear to work on, but if your handy with tools and have some experience working on cars, you can probably do it. A Chilton Repair Manual for your model Saturn could prove invaluable in accomplishing this repair. You can pick one up at any national chain, auto parts store.
Posted on Apr 06, 2011
Has anyone ever had water in the reservoir of an radiator mixed with oil in a 4 cyclinder 1998 saturn engine I had the head gasket changed and everything flushed but now I see water in the radiator.
Oil in the cooling system can come from two places. First is the head gasket or from a crack in the cylinder head. Could be residue from previous failure...If so, cleaning it out should get rid of it.
If your engine oil has any coolant in it or you are overheating or loosing coolant, though the job was just done, head could be cracked or warped. Second place oil can come from is the transmission cooler in the radiator. (automatic trans only) If it fails trans fluid (oil) will get into the cooling system. That oil is red in color and usually easily identified. Only way to fix that is to replace the radiator, but be sure it's that before buying one.
Apr 16, 2011 | 1998 Saturn SL
What oil should i use for my 96 saturn sl2
The engine on a 1996 Saturn SL uses SAE 5w-30 engine oil. The recommended oil-change interval for this engine is every 3,000 miles or three months, whichever comes sooner.
This will help.Thanks.Helpmech.
Feb 02, 2011 | 1996 Saturn SL
Does the trans cooler exist inside the radiator on this V6 engine/auto trans combo? I found a brown foam in my 2001 Saturn V6's coolant overflow tank. It was so thick, i could not read the coolant level. ...
hmmm..........there is a OiL COOLER tube for the transmission cooler in ur radiator, that to keep ur tranny fluid to cool down!
As u said, u checked the engine oil, and it has no decrease on oil level!
Ur right about that... better bring that to ur mechanic and evaluate the radiator, the tube inside might have been damage or corroded!
Hope the seals up ur probs!
Dec 04, 2010 | 2004 Saturn L-Series
Why my saturn mortor oil when in the radiator
you have a bad gasket or a crack in your engine. that is why there is oil in your coolant and vice versa. get this seen to ASAP by a hands on mechanic, not a good thing
Nov 22, 2010 | 2003 Saturn VUE
WHERE IS THE DRAIN PLUG FOR 1996 SATURN SL RADIATOR
If there is one, look at the lower part of the radiator on left side as you face the vehicle. Out of all the vehicle I own only 1 has a drain valve on it and most of the time it is clogged from road splash and dust. You can remove the lower radiator hose either from the Radiator or the engine to drain the radiator.
Oct 29, 2010 | 1996 Saturn SL
What kind of oil filter does a 1996 saturn sedan 1.9L need?
Go to walmart auto section. they have a book there which provides this info. If you can't read, go to a parts store and the salesman will look it up for you for a higher price. any oil change place will also have these in stock. All saturns 91-99 had the same L4 1.9L engine with the same filter.
Sep 22, 2010 | 1996 Saturn SC
There is oil getting into my radiator not a lot but surely in there and ideas it is a 1998 saturn wagon
what colour of the oil--- there can be two problem the tranmission cooler is leaking or the head joint blown ---- your engine ever over heat?
Aug 04, 2010 | 1998 Saturn SL
Engine oil in radiator ,no water in oil engine not over heating ,runs well ,possible fault. please
If you keep adding engine oil you have a blown head gasket. there are only two ways for oil to get in the radiator. blown head gasket, some one mistakenly add oil to the radiator
Jun 21, 2010 | 1996 Honda Accord
Looking for the thermostat location 1996 saturn sl
follow the top radiator hose back the the engine. You will find the housing there with 2 bolts.
EZ fix
Dec 25, 2008 | 1996 Saturn SL
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
