Question about Schlage FE595PLY626FLA Satin Chrome Electronic Security Plymouth Keypad Ent
My doors holes are 3"in
  • 963 Answers
According to the manufacturer's installation instructions, if the existing backset is not 2 3/8" or 2 3/4", then the lockset will not fit properly on the door.
Posted on Apr 10, 2011
How to install new door lock
For a residential door, you may choose either 2 3/4" (70 mm) backset or 2 3/8" (60 mm) backset. Some locks are not adjustable.
Choose the backset required for the lock. Check the thickness of the door. Standard installation height is 35-36" above the floor.
Bore a 1" diameter hole into the edge of the door and a 2 1/8" hole through the face. A drilling jig helps align these two holes. If you measure and mark the holes carefully and drill accurately, it can be done without a jig, but for about $20.00 the jig helps avoid lock alignment problems or possibly trashing a door. Follow the instructions for the jig and the lock manufacturers instructions.
Jul 09, 2014 | Ace Hardware Ace Door Lock Installation...
How do I adjust spring loaded hinges?
Using a drift punch that fits the hole , place drift into bottom hole.
Twist to increase pressure(one hole only. Reposition pin one hole tighter.
Repeat to other hindges.
Jun 11, 2014 | National Grid National Hardware V127...
I recently purchased a Toshiba laptop, model #S855-S5254 . I am unable to open the door to the DVD player. Does anyone know if there is a lock on it, or how to access the "unlock" if so.. Please help
If the eject button doesn't open the door, try going into 'My Computer', then right-clicking the DVD drive, then click 'Eject' on the menu that pops up. Maybe that will get it open for you.
Dec 14, 2012 | Toshiba Satellite S855-S5254 Laptop
How do you open up door to acess power window switch 2007 mazda 3
Places to look for screws (general guide, not model specific):
1) within the door opener latch. Pop out any plastic backing plates.
2) Beneath arm rest area. Pop out the arm rest if possible and inspect. Some screws may be located under a thin rubberized matting which sits in the arm rest/ door grab handle recess.
3) Within the window switch cluster. The window switch cluster can be popped out on many models, without the need to remove the door panel.
I haven't removed a Mazda 3 door panel before, but I have removed a Ford Focus panel (Based on the same model) and the panel pretty much just all popped off.
The trick to removing panels is to pop off whatever you can, and then feel for where any tight bits may be, then look at that location carefully for screws or other types of retaining clips.
Oct 31, 2012 | 2007 Mazda 3
Cable system on passenger door power window, 1999 dodge Caravan, has slipped off track. Need exploded diagram to restore to original.
REMOVAL
1. Remove the watershield. (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD - REMOVAL)
2. Remove door glass retaining clips and secure the window in the up position using masking tape or equivalent(FRONT DOOR GLASS CLIPS).
3. Disconnect wire connector from power window motor, if equipped.
4. Loosen screws attaching front and rear window guide rails to inner door panel (FRONT DOOR MANUAL WINDOW REGULATOR - TYPICAL).
5. Remove screw heads on guide rails from key hole slots in inner door panel.
6. Loosen screws attaching regulator to inner door panel.
7. Remove regulator from inner door panel.
8. Extract rear guide rail through inner door panel rear access hole (FRONT DOOR POWER WINDOW - TYPICAL).
9. Extract front guide rail through front access hole.
INSTALLATION
1. Insert front guide rail through front access hole.
2. Insert rear guide rail through rear access hole.
3. Place window regulator in position on inner door panel.
4. Place screw heads on guide rails in position through key hole slots in inner door panel.
5. Tighten screws to attach front and rear guide rails to inner door panel.
6. Connect wire connector into power window motor, if equipped.
7. Install door glass.
8. Verify door glass alignment and operation.
9. Install sound shield and door trim panel
DIAGRAMS CAN BE FOUND ON JUSTANSWER,COM
Sep 02, 2012 | 1997 Dodge Grand Caravan
It says "close door or
There is a switch inside the front door (cartridge door) on the left side, you can see it in a little hole in the black plastic. Inside you can see the metal part of the switch. If you press it you can ear the "click" of the switch. This switch must be pressed to clear the message " close door". Probably it's only out of regolation, you can by-pass it if you insert a small piece of paper inside the hole to close the switch.
Apr 27, 2011 | Lexmark T630 Laser Printer
89 F250 460 door sticker says trans code "k" what
Transmission Types : Ford E4OD/4R100, 4 Speed, Automatic Transmission
Comments: w/ Shallow Pan = 20 bolt holes 4 speed
Drive Trains : Four Wheel Drive
Transmission Types : Ford C6, 3 Speed, Automatic Transmission =17 bolts 3speed
What does the dash indicator say and does the stick have an od button on it? there is only 1 3 speed for the 460 and only 1 4speed for the 460
Engines:{300, 302, 351w}, {400, 351m, 460}, {6.9L, 7.3L IDI}, {352, 360, 390, ect.}
Fluid:
Pre '77: Type F
Post '77: Mercon
Display: PRND21
Pan 17 bolts "Utah" shape
Ratios:
1st 2.46:1
2nd 1.46:1
3rd 1.00:1
Trans code: K
so you should have the 3 speed acording to the code
http://broncozone.com/topic/10386-transmission-id-chart/
Feb 27, 2011 | 1989 Ford F 250
My washer has about 3 inches of standing water and during the wash cycle stops and says "suds or pump is blocked."
Welcome to FixYa.
Based on your post,
this is usually the bi-product of the unit not draining properly due to too much detergent or a clogged pump filter.
These are the steps I'd suggest you take to move forward...
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful...I usually cover the edges with electrical or duct tape or wear welders gloves).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
( you should also see a ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
macmarkus_31.jpg THIS RELEASES THE DOOR LATCH IF PULLED
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap.
Hopefully you'll find the item/debris that initiated the poor spin error here.
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, or door lock but I would certainly start by performing the things I listed first, the motor is very unlikely.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Dec 02, 2010 | Bosch Nexxt 800 WFMC8400UC
Schlage FE595PLY626FLA Satin Chrome Electronic Security Plymouth Keypad Ent Logo
57 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
