Question about Midea Chest Freezer MCCF10WMD
Midea freezer, 100 liter, everything looks normal but is defrosting. how to fix it?
LOOKING FOR DOOR HANDLE FOR MIDEA UPRIGHT FREEZER
Fixya does not sell Midea freezer parts.
Feb 13, 2018 | Midea Freezers
Everything in our freezer is frozen solid except for the ice cream which is soft and mushy, the freezer is only about 3-4 years old and we checked and it is turned up to the coldest setting, any ideas what...
If this is a self defrosting model make sure that you don't have frost build up on the back wall of the freezer causing the air not to circulate like it should. If you do have frost build up other items will eventually start thawing as well. If this is the case you have a defrost problem.
If this is not a self defrosting model then make sure it does not need defrosting.
You normally will notice ice cream being soft before you notice other things thawing.
Also make sure the door is shutting good and you may try putting the ice cream in a different location.
Jul 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Ice under the cover
You can use a hairdryer to speed it up but you need to fix the defrost sytem.
How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 20, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Hi,i would like to know how to set the traulsen intela-tarul digital thermostat and how to put it in defrost mode
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Part 257 on this diagram is your defrost timer http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=TFX22JABAAA&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-B-SERIES&diagramPageId=00005&componentDescription=FRESH%20FOOD%20SECTION&documentId=E2134230&backToLink=Return%20to%20Sub%20Components%20list
Aug 19, 2009 | Traulsen 24.2 cu. ft. / 685 liter...
Old hotpoint upright freezer only has 1 temp artic blast....
I would replace the thermostat because is the only thing that controls the temp. , also there's a timer and a terminator but them are only for defrosting the unit.
Aug 13, 2009 | GE 16.7 cu. ft. / 473 liter Upright...
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Oct 28, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Kenmore manual upright freezer
we got alot of ice chest and cleaned out the ice. this fixed the problem so far. we dint lose any food thank goodness.
Jul 07, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Noise
When the freezer goes into defrost mode, some thumping/popping noises can sometimes be heard as the defrost heater melts the ice built up on the evaporator. Quite normal.
Nov 01, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Midea Chest Freezer MCCF10WMD Logo
48 people viewed this question
Top Midea Freezers Experts
mike cooper
Andrew Taylor
Andrew Taylor
Al
Al
Are you a Midea Freezer Expert? Answer questions, earn points and help others
