Question about Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver
My Bose companion 3 remotes led is flashing yellow. If i touch it, it turns green for half a second and then flashing yellow again. Whats wrong?
4 Suggested Answers
cjackHD
  • 71 Answers
SOURCE: Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Posted on Jun 21, 2009
  • 10 Answers
SOURCE: Where Can I purchase a bose companion 5 control pod?
you have to call customer service at 1-800-367-4008.Run about $35.
For the broken cable, have you tried to fabricate a new cable for it?
Posted on May 25, 2009
  • 9 Answers
SOURCE: can i connect my bose companion 5 to a lcd t.v
yes use an auxilliary
Posted on Jun 17, 2009
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
My bose solo has a yellow light instead of green
The yellow light means you are in reduced bass mode. Hold the mute button on the remote for about 3 seconds and you'll hear 3 tones going up and the light will switch back to green. Enjoy!
Mar 01, 2014 | Bose Solo TV sound system - Black
I have a Bose sound system companion series 3 ii and the lights just yellow and no sounds coming out and it turned red and no sound was still coming out.It was working fine about half a an hour ago
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
Dec 25, 2010 | Bose Companion 3 Computer Speakers
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
Bose Companion 3. Speakers are very faint in sound. The touch pad seem inoperable. (the green light on pad does not come on.)
Check first that you have connected the speaker to the right output. For example on many computer there is an aux output marked in blue that can give you this problem.
If the problem does not depend from the source, then that sounds like an internal fault on your Bose system.
Leave the Bose unplugged from power and from computer for one hour, to get rid of electrostatic charges accumulated inside capacitors.
If that does not get rid of the problem, then there is an internal fault, either a short on speaker wiring, or a fault on the internal amp circuit board.
Mar 05, 2009 | Bose Companion 3 Computer Speakers
Bose Companion 3 Series II not working (Mac)
The speakers seem to be muted by default - you'll see that the LED is yellow/amber. Tap the control pod - the LED will turn green and speakers will work. I felt like such an idiot after I spent almost an hour trying to figure this out. (This feature should be more prominent in the manual.)
Dec 20, 2008 | Bose Companion III Computer Speakers
Bose companion 3
This is a common problem it seems with the electronics within the speaker set. (Companion 3 with sub and remote pod, aka, 'puck' = help desk support term)
I bought the multimedia speaker set in 2004 and had it replaced in 2005 because the 'puck' would not turn on (no orange light nor green light.) So I called help desk and they accepted the warranty exchange and I mailed the entire system (speakers and all) back to Bose in Markham, Ontario, Canada and they sent it back several weeks later. It worked 5-6 years after that as it is 2009 now, and it has the same problem again (no light on the puck). So I called help desk again and was ran through the same tests again (on/off, power plug off, various audio inputs, etc.) and the guy said to mail it in and they'd fix it as a non-warranty item. Cost: $85(Cdn) for repair + taxes, and $39 for remote pod.
So the sound that I got to enjoy from the Companion 3 system was amazing but electronic quality is very poor. For a set that cost above most other home user sets at FS and BB, it is substandard longevity.
I like Bose and have no complaints about the sound, but I will not buy another Bose multimedia package because at $350 (in 2004), I would expect it to outlast other sets. My friend bought a Logitech speaker set from another company in 2003 and is laughing at me as he realizes this is my second set and it hasn't even lasted as long as his own set.
Dec 03, 2008 | Bose Companion 3 Computer Speakers
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Bose companion 5 problems
Have had Bose companion 5s for about three years. The external volume deveice in not active. If I unplug it, the sound goes dead. The indicator light is stuck on green and is very dim.. The touch feature does not respond nor does the volume. Sound is set very low an barely audible. Can I get replacement external volume control or is the problem inside the base unit itself? Any help out there with a similar problem.
Thanks JT
Apr 10, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Logo
196 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
