Question about StarTech.com StarView SV211K 2-port KVM Switch
Eurovox problems i have a eurovox max box, and am aware of the big maq code updates, but i have just done a power scan and now i cant get a single channel !!! i have checked the latest codes and i have put them in correctly, PLEASE HELP!!!
  • whiteroy Nov 30, 2008
    THANKS VERY MUCH FOR YOUR HELP, MUCH APPRECIATED, YOU ARE A STAR!
Can any one help star view box c/w warrington new codes thanks
Posted on Dec 03, 2008
  • 73 Answers
Try using these if you have telewest updated 29/11/08 3.00pm
5A 01
98 B0 BA 52 D3 21 08 B4
D2 EA 29 B7 B5 52 E9 AD
Posted on Nov 29, 2008
Can any tell me how to setup a eurovox its the 2007 version ive scanned the channels theyve all came up but skysports, movies and all the other channels you pay for wnt come on. i used to have a starview...
Dont know if it helps or not but this is the method i used to set up the eurovox max when i first got it - it may work for you.
EUROVOX MAX SETUP
This is the method I use for setting up the eurovox max box but I have been told that it works for versions 1 and 2 as well
PLEASE NOTE : IF YOU ARE USING A SPLITTER IN YOUR SETUP THIS MUST B E REMOVED for the initial POWERSCAN as the box needs to scan from a pure signal- this will ensure all channels being found. – scanning throught a splitter can result in the loss of 50+ channels.
Firstly before you start to scan the box you need to:-
PRESS MENU
GO TO CONFIG
GO TO CLEAR DATA – IF IT ASKSYOU FOR THE PIN PRESS 0000
SELECT – ERASE ALL CHANNELS
Then it will ask you are you sure so press OK
Then wait a few seconds then press EXIT and EXIT again
What you need to do now is a POWERSCAN.
The following is a step by sep method of carrying it out!
Press the MENU button
Go to INSTALLATION and arrow right to USER INSTALLATION
Type in your pin (normally 0000)
Press the YELLOW button for POWERSCAN and change the mode to FULL from Normal by arrowing right to reveal FULL
Now press OK, this will begin the BRUTEFORCE POWERSCAN which can take up to 40 minutes,but it is guaranteed to find every single channel on the network in your area.
Once done the box will switch to a random channel to indicate it has finished !
You will now have around 240 or more channels (in some cases regions can receive up to 330 channels!)
You now need to switch to a non free channel and let the box update the codes – this could take a minute or two, it will indicate on the screen “updating please wait” once finished all channels will now be unlocked.
That’s it you’re all done … HOWEVER …. If you find that you get no channels at all there is a further adjustment you can make to ensure you get the 250 plus channels that your area box will be able to receive and again it’s quite simple to do!
First press MENU
Then go to USER INSTALLATION
Type in your pin (0000)
Press YELLOW button to POWERSCAN
Then change the mode to NORMAL
Then arrow down to the SYMBOL RATE and if its on 6.952 then change it to 6.887 (or vice versa!!)
Then press OK and it will carry out a scan like the powerscan of before.
If after you have tried this and you still are channels short then keep the symbol rate at the new figure but adjust the scan to FULL and try again.
Sep 16, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes!
download the Bigmaq toolbar,all updates and fixes are on there,you need a null modem cable available from ebay or your local maplins etc to connect the box to your computer.flashing takes a couple of minutes,read the eurovox section on Techwatch.co.uk for guides and help.Regards stu.
Sep 09, 2009 | StarTech.com StarView SV211K 2-port KVM...
Codes needed for eurovox box ntl
try downloading the big maq tool bar. all codes are on there and they are pretty quick on updateing as well
Did power scan by mistake and now no channels
restore to factory defaults and than delete all the data ( all the channels ) once done . run power scan and your box should be up and running again..... :)
Jun 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox problems
update your firmware theres a new fix on the bigmaq site easy
Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
I have eurovox max 2008
due to upgrade in the software of the eurovox and other recievers you will need to upgrade your box once you have done that power scan your box and it should be up and running.
Dec 01, 2008 | Audio Players & Recorders
Eurovox update codes
my euro-vox max channels not working please help me....
Oct 14, 2008 | StarTech.com StarView SV211K 2-port KVM...
Codes
Yes big Maq is Now Chatterbox Toolbar
I have found the one below a lot better
It has all your Cable needs
And you will not have to update Keys again .....Paul
http://TechnoSource.OurToolbar.com
Jul 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
155 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
