Question about Craftsman Drills
I have a wobble at the chuck, seperated from the arbor the arbor it's self doesn't appear to be the problem when running alone. where should i be looking to correct this.
  • 2,176 Answers
I would look at the taper shaft and the chuck jaws/chuck for the problem, Ii is very seldom that the internal socket for a tapered chuck/arbor to be bad it has to be on the outside.
Posted on Apr 06, 2011
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    Ryobi DP101 bench drill press chuck is off by 1/4". How do I remove the chuck? Could it be something else causing the rotation to be so way off?
    yes, a bent arbor could be causing this... sometimes they can be straightened... or by a new arbor
    Oct 25, 2013 | Ryobi Drills
    The adjustable chuck on my sons Jet JHM-610 comes off when using it in the milling function. What is the best fix for my situation? It is coming off at the taper.
    You should really be using end mill tool holders for milling. The torque is too great for drill chucks. You will get better results machining with surface finish, size as well as longer tool life. Side note..take care with reassembly of drill chuck. Tapers must be dirt and burr free or chuck will have run out as well as taper lock will break and come apart on you more often. If there is damage to the tapers replace the arbor and or chuck with new.
    Apr 29, 2011 | Jet JHM610 Hobby Mill Drill
    How do you change the chuck out?
    if it has a slot in the spindle, there was a wedge that came with it, put the wedge into the slot and strike it with a hammer. depending on the taper fit you would need something like a ball joint seperator to knock the arbor from the chuck body. that is the best I can do without knowing the model and brand of the tool
    Jan 25, 2011 | Wilton Drills
    Dayton drill press, How do you remove the chuck? It has a Wilton 1/2 chuck 3z568 model
    If the spindle has a slot in it above the chuck and you can see the top of the chuck arbor in that slot then you need to get a wedged piece of steel commonly called a drift , insert in the slot so it bears on the top of the arbor and the top of the slot and hit it with a hammer. This will knock the tapered arbor loose from the spindle and it should fall out. Hope this helps you.
    Jan 26, 2010 | Drills
    Chuck falls out of drill press
    There is a long tapered hole in the spindle of the press known as a Morse taper. It holds a 6 or 8 inch morse taper arbor which is attached to the drill chuck. This is made to be removed frequently by putting a wedge shaped key into a horizontal hole in the drill press and giving it a little tap. This is for making tool change that involve removing the chuck. If you had two such tools (say two different style chucks) they would each have their own dedicated morse taper arbor. But there is also a short tapered cyclinder on the chuck end of the morse taper arbor, with a matching hole in the back of th chuck. This is not intended to come apart frequently, but it can be disassembled. I'm not sure which one is coming apart, but regardless of which one it is, you might try this fix. Clean up any bumps at all on the oustide of the taper and inside the hole with sandpaper 200 - 300 grit. Use a dowel to hold the sandpaper in the hole, and use the motor to spin it. --- JUST BE CAREFUL that if it grabs that it doesn't grab you! Once it's all cleaned up, you can you the press aspect of the drill press to seat it in place. You also might have to replace the arbor. They don't cost all that much and are available from Grizzly.com. You specify the particular taper for BOTH ends of the arbor. The long end is a Morse 2,3 or 4, and the short end is specific to the drill chuck manufacturer, like JT-2 (Jacobs chuck taper 2). Write back if you need more help.
    Jan 07, 2010 | Drills
    Hello. My DC728 keyless chuck took a dive. I had
    the chuck is screwed also to main shaft. counter clockwise to remove.
    Nov 28, 2009 | Drills
    Craftsman 10" bench drill press chuck wobbles
    If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
    Oct 07, 2009 | Craftsman Drills
    Damaged chuck
    Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
    May 14, 2009 | Makita 5/8" 2 Spd Hammer Drill
    Drills Logo
    286 people viewed this question
    Top Craftsman Drills Experts
    Gareth Cockram
    Gareth Cockram
    John Trevino
    Are you a Craftsman Drill Expert? Answer questions, earn points and help others
