Question about Microsoft Windows Vista Ultimate Edition
Window vista dvd drive
My dvd drive does not read any cd or dvd.which cd or dvd drive cleaner do you suggest? there is no software problem in it
  • avanna23_02 Aug 29, 2008
    my dvd driver does not read any cd
  • Thomas Christopher
    Thomas Christopher May 11, 2010
    How old is the computer?
    Sergeant:
  • 336 Answers
The drive could have burned out and stopped. I would try the drive on another computer if it is an external drive or I would take to a tech place.
RCF
Posted on Aug 31, 2008
SOURCE:
I NEED A SOFTWARE OF HITACHI DVD-ROM GD-5000 DRIVERS, BECAUSE MY EQUIPMENT THERE IS NOT IT, PLEASE, CAN SOMEONE REOLVED MY PROBLEM? thanks
Windows XP and Vista and 7 all contain "built-in" support for reading CD and DVD drives.
If your computer cannot detect your hardware, replace that "dead" CD/DVD drive.
Jan 19, 2011 | Computers & Internet
My dvd writer cannot read DVD-Video Disc,but can write all dvds
Dear i have send a some information of your problem.
i have found some links please read this carefully.
and these links are help full of you.
Thanks.
The jerky pictures and poor sound quality are most probably caused by the IDE controller (the computer has an IDE hard disk drive) not being set to Direct Memory Access (DMA) mode, which allows the DVD drive to transfer data directly to the RAM memory instead of via the processor. The alternative mode is called PIO mode, which makes use of the processor. During a DVD movie, the processor's workload gets too heavy and the stress on it makes the video become jerky and the sound quality deteriorate.
The following article should contain all of the information you need to fix the problem.
DMA reverts to PIO - http://winhlp.com/node/10
First try playing different DVDs, preferably pressed DVDs instead of home-recorded DVDs, in order to make sure that you didn't just try to play a bad DVD.
Dell used to provide Recovery CDs with all of its computers, which it still does with its business computers. You can still buy the Recovery CDs as an option during the purchase of a home computer, but for the last few years, in order to cut costs, if the purchaser doesn't buy the CDs, Dell uses a recovery partition on the hard disk drive where all of the recovery files are stored. The recovery procedure is started from the command prompt, which you can open by entering cmd in the Start => Run box in Windows XP, and in the Start => Start Search box in Windows Vista.
It would be time-consuming and difficult to describe how to remove and reinstall the DVD decoder, so Dell's support suggested the easiest method of recovery from the company's point of view, and the worse method from your point of view. In any case, the problem might not even be software-related. It could easily be caused by faulty hardware. Sometimes, even though a drive can recognise and read CDs, a hardware fault could prevent it from recognising and reading a DVD.
That said, the cause of the problem is more likely to be software-related, so, I suggest using the Windows DVD Troubleshooter. To run it in Windows XP, click Start => Help and Support. Under Pick a Help Topic, scroll down to Fixing a problem and click on it. In the window that comes up find Games, Sound and Video problems, and in the right-hand window, click DVD Troubleshooter. To find it in Windows Vista, enter DVD Troubleshooter in the Search box of its Help and Support.
This MS Knowledge Base article provides other suggestions: How to troubleshoot common problems that may occur when a Windows XP-based computer cannot read a CD or a DVD - "This article describes how to troubleshoot common problems that may occur when a Microsoft Windows XP-based computer cannot read a CD or a DVD in a disc drive. This article contains several methods that you can use to try to resolve these problems." - http://support.microsoft.com/kb/321641
If you don't have the CD that contains the DVD decoder software, it might be difficult or impossible to locate. Usually, the DVD decoder software that comes with a DVD drive or PC has a condition of its licence that it can only be distributed with the DVD drive for which it is licensed, which means that it is not usually made available as a download. Fortunately, your PC uses Sonic Solutions software, which can be downloaded from Dell's Support site here: http://support.dell.com/.
You could also try using a free 30-day trial of Cyberlink's PowerDVD software from http://www.cyberlink.com/. It is generally regarded as being superior to Sonic Solutions software and the Windows Media Player. If you decide not to buy Cyberlink's PowerDVD and uninstall it after the trial period, it leaves behind the MPEG2 codec, which allows you to play DVDs using the Windows Media Player.
If the problem is hardware-related, you'll have to replace your PC's DVD drive. DVD drives/writers are currently very inexpensive, especially when compared to the prices of Blu-ray drives/writers.
Feb 19, 2010 | LG GH22NP20 22x Internal DVDRW Retail Kit...
Need driver and software
Drivers are not needed for DVD/CD-Rom drives for Windows 2000, XP, Vista or Windows 7.
You can purchase whatever software you wish to use with it online or at a retail store. LG OEM drives don't typically come bundled with software. I would suggest Nero by Ahead Software.
Jan 23, 2010 | LG GSAH55LK DVD±R Dual Layer Burner
My dvd player on my HP Pavilion is not reading my
If you are using Windows vista home basic or any lower version like windows XP, you need a decoder. Your options are
1: buy a decoder pack. (Search DVD Decoder pack on google or bing and you will get may options).
2. Download and install a DVD player software like cyberlink powerDVD, However once after getting everything to work, you may need to change from trial version to a full function version.
Nov 10, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My CD Drive doesn't work and will not read anything
Sounds like you need reload the driver in usb and see that works ore you need replace the cd /DVD reader for it
Jul 28, 2009 | Computers & Internet
DVD/RW does not reads DVD,But reads CD
no thats not cause man. i suggest you need a dvd playback software for that. like power dvd
May 12, 2009 | Computers & Internet
Cd\dvd drive won't read software cd
Just a suggestion, try to update your drivers.. If you have installed any third party cd burner just uninstalled it. after uninstalling, clean the registry via ccleaner, regcure, or any other 3rd party cleaner... then update your drivers... most of the 3rd party cd burner software are damaging your cd drivers...
gud luck
Sep 27, 2007 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
Microsoft Windows Vista Ultimate Edition Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
