Question about Minolta EP4000/5000 CS/PRO Copier
ERROR CODE 0520 IN MINOLTA 5000 PHOTOCOPIER - Minolta EP4000/5000 CS/PRO Copier
  • 17,970 Answers
C0520 - High fuser temperature
This error relates to a problem with the fuser, are more specific to a problem of temperature, to reset this error so you have to enter technical as you say and you will see an option that puts you "counter" see another option in "trouble" there looking for the error in the list, to reset press "C"
Good luck.
Posted on Apr 06, 2011
Code d'erreur C0F10 de photocopie Minolta cspro ep5000
Remove the Large glass below it you will see a pulley in the middle to the right of the pulley you will see a lens assy. off to the right of the lens assy. (looking from the left side of the copier) near the front side of the lens assy. is a small sensor the monitors the Exposure lamp. that sensor is causing that code. Open close front door to reset. if it comes back replace the sensor will be hard to fine due to the copier is a legacy machine from Minolta now Konica Minolta. try link below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 10, 2014 | Minolta EP4000/5000 CS/PRO Copier
How to resolve code error c0610 in minolta photocopier
CO 610 lens motion failure.Check or replace the lens reference position sensor or correct or replace the cable or part being overloaded.
Dec 15, 2011 | Minolta EP4000/5000 CS/PRO Copier
C koi code c0610 de photocopie minolta ep4000
Lens Motor malfunction that is a motor located under the big glass, to reset open front door, up left small access cover remove, press small left switch, if the code comes back then you need a new motor
if some one cleaned the lens system might have damaged the lens motor, try this site for parts Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Nov 15, 2011 | Minolta EP4000/5000 CS/PRO Copier
Error code 0520
Apr 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Apr 10, 2009 | Minolta Office Equipment & Supplies
Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Mar 22, 2009 | Minolta EP4000/5000 CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
396 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
