Question about Garden
Inherited an E P 190 propagator but no instructions about the heating controls.(1 to 7) Quite simply is number 1 the highest or lowest setting. Thank you for any help which you may give.
the dr
  • 447 Answers
SOURCE: kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Posted on Dec 04, 2007
  • 306 Answers
SOURCE: My LG B197WV has a
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Posted on Jan 13, 2009
Molson02536
  • 3854 Answers
SOURCE: air conditioner/heater only works on number 3 on setting
It could be the switch or the blower resistor has gone bad. You can check the wire leads to the blower resistor for any power problems which would indicate a speed switch issue. If all the speed setting has good power at the wire leads to the resistor, then it's gone to be a bad blower resistor and you can pick on up at Auto Zone and there will have the step by step instructions to getting the job done with common tools. Good luck and keep me posted, be glad to help you get your trailblazer running 100%
Posted on Aug 06, 2009
shocktroop40
  • 155 Answers
SOURCE: 2002 Honda Odyssey fan only works at high speed. The A/C compress
Usually when the blower fan only operates on hi speed, its because of a failed blower motor resistor. You still have hi speed because on hi, the power going to the blower motor goes directly to it, as opposed to the lower speeds, when the power is routed through the resistor, thus lowering the voltage, which in turn lowers the speed of the fan. The resistor is usually located near the blower motor itself, under the hood back near the firewall.
Posted on Aug 15, 2009
johnjohn2
  • 5763 Answers
SOURCE: Kia Sedona 03 front heat only works on high
replace the blower motor resistor that should solve your problem.
Posted on Dec 24, 2009
NTFS permissions server2012- not propagating down to child objects
Look for a box labelled "Apply these permissions to objects and/or containers within this container only" in Advanced security
Aug 12, 2015 | Computers & Internet
Coldest setting 1 or 7
On my fridge it also says ? C, meaning the 1 to 7 are degrees Celsius. Making the one the lowest and the 7 the highest temperature.
Jul 28, 2014 | Whirlpool Refrigerators
Quantaray lense wont work on nikon D50
David -
The lowest setting is the highest number; f22 is lower than f4. It's little counter-intuitive, but the lowest setting means the least amount of light - or the smallest aperture opening - not the numerical "f" value of the opening.
Simply twist the aperture ring until the highest value "f" number is selected. Many lenses have a small tab or latch to lock them in this position - if yours does, you can use it to prevent this from happening again. You would use a command dial on most camera bodies to electronically change the aperture opening.
May 16, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
I have a new Sears 315mhz garage door opener and the door fails to reverse when an object is placed under the door
It sounds like the force adjustment may be set too high. Check this:
The force adjustments control the pressure used to open and close the door. A new garage door opener from the factory is set to the lowest possible force adjustment. If you have a properly balanced door, the forces required to open and close the door should be minimal.
The force adjustments are usually located on the rear of the garage door opener and/or under one of the light lenses, If your opener has two lights. If you have lights on the side of your opener, the force adjustment will be located under the right light lens. The force adjustments are labeled with an arrow indicating open or close and numbered 1 to 9, with one being the lowest force and nine the highest. The force adjustments can only turn 260 degrees, or ¾ of a complete turn. Changes to the forces should be done in 10-degree increments. Please remember that too much force will interfere with the proper operation of the safety reversal system. Do not increase the force beyond the minimum required to close the door. Do not use the force adjustments to compensate for a sticking, binding, or unbalanced door.
Mar 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Heat settings on enheat slow cookers
Generally, the lowest number is the lowest temperature setting and the highest number is the hottest temperature setting
Jan 02, 2010 | CorningWare SC60 Slow Cooker
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
Jan 13, 2009 | Refrigerators
How to get the refrigerator at the coldest point
set the freezer control to lowest setting and the fresh food or the ref control to the highest setting
some companies use letters some use numbers so
freezer to a or 1
ref to g or 6
Apr 22, 2008 | Refrigerators
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
