Question about Casio Parts Cash Register PC Desktop
Hi when I turn my till on there is no power i have put a new fuse in the plug but it wont switch on.....it tries as the till reels move it is a samsung6500
  • 101 Answers
Was it the exact same fuse? Stuff like that will happen if the measurements arn't the same.
Posted on Apr 06, 2011
Tiller will not start changed plug and cleaned gas and lines
check for a stop switch or wire from the switch being shorted out
Apr 17, 2016 | Yard Machines Garden
Turn signal flasher location
fuses first, usually its 1 fuse but some cars have 2.L/R
remove all left lamps. (lamps can short !)
put a new one in.
does it work?
yes,
now move it to the other end,
does it work? i bet yes. (not both work , try it)
if not someone , cut the wires, for trailer hitch (uhaul blunders)
or collision damage that side. f/r/
if all checks fail, the combo switch is dead.
one other test with new lamps, is try the emergancy flasher ,button, does that work?
Oct 08, 2013 | Jeep Liberty Cars & Trucks
Brack lights wont light up on my 1988 ford ranger we keep blowing fuse and put in new brake switch
If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
Sep 04, 2013 | Cars & Trucks
I have a teac 2300s tape deck. My problem is when i press the rec / pause or rec play the 2 meters slam to the right. They don't move while recording,but the deck will record and playback. Putting the...
The leads to the VU meters have shorted out. The fact that it only happens when you push "Record" sounds like part of the mechanism is actually causing the short.
Jul 15, 2017 | Pioneer Rt-1011l Reel To Reel Tape Deck...
I have a. 2007 road king custom and when I turn the ignition switch the fuel pump starts and when I start the bike it runs alittle and then the fuse blows ...put in new fuse and run the bike 10-30 miles...
Hi Wayzach, you could have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and connect it to the power side of the, circuit breaker, relay or the blown fuse receiver, start by tracking the out bound wire towards the ignition switch and beyond if necessary, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below. Good luck and have nice day. Harley Davidson Wiring Diagrams and Schematics
Jun 27, 2011 | 2007 Harley Davidson FLHRS Road King...
Hi my washing machine door wont open, feels like the lock has broke ??
hi have you tried turning machine off at plug for a min then power back on put on a cycle press start. wait till it starts to fill and press stop and hold down the reset button till it beeps and wait till door unlocks. Or a quick way to open the door is unclip the foot kick stopper at bottom front of machine and pull the emergency door open which is a thing peace of hanging plastic. if none of this works try starting a cycle then press stop soon as it starts to fill and turn off on machine not at plug. hope this helps.
Sep 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
When i turn off the car the brake lights stay illuminated. the only way i can turn them off is by removing the fuse....whats the problem?!
hi if you check where the brake pedal is pivoted under dash you will see the brakelight switch ? it is screwed into the box section and has a 2x wire plug to it this switch has aplunger in it which contacts the b/pedal and as pedal is pressed the plunger moves out and makes the connection to put b/lights on then pedal released the plunger is pushed back so lights go off what may be wrong is either plunger is broken off or just simple wear on plunger which is easily rectified by unplug of wires/plug then screw the switch in a a couple of turns ? then check with pedal off ? the plunger is pushed back? reconn the plug then if lights are off press pedal till lights come on pedal movement approx 3/4 " this is simple trial/error adjusting till you are happy ? hope this helps?
Dec 11, 2009 | 1999 Volkswagen Golf
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Wii wont switch on
hi the same sort of thing happend to me i put a new fuse in the plug it is ok now try it if not take it back.
Oct 12, 2007 | Nintendo Wii Console
Casio Parts Cash Register PC Desktop Logo
19 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
