Question about Lexmark X1270 All-In-One InkJet Printer
When i opened my lexmark 1200 printer to replace the ink cartridges, i noticed a long thin strip of plastic was loose. and now the cartridges dont move back and forth smoothly but clunk to either side and i cant print anything now because of it. on the left side of the strip are the letters/numbers J3300XA and an arrow. on either end of the strip is a small hole which i'm assuming latches on to something inside the printer.
  • Official Brand Answer
  • 3,344 Answers
If the encoder strip has become unseated: 1 Turn off the printer and disconnect the power cable from the back of the unit. 2 Open the printer's front cover. 3 Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer. 4 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and back up to get it into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it first forward and then back. 5 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt. 6 Reconnect the power supply and turn the printer back on
If you need some graphical reference, please refer to this article: Printer Cartridge Stalls or Is Blocked .
Posted on May 03, 2011
I have just placed my cartridges in the lexmark printer, turned the power on and then suddenly a thin plastic strip flew out, please how can i put this strip back and where. The printer is a X2550 lexmark
Did you remember to peel off the film strip that covers the area where ink exits the cartridge (toward the bottom)? If not, then that was probably what you saw.. I have done that before myself.. : )
Nov 29, 2010 | Lexmark X2550 All-In-One Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Ink cartridges make a slamming sound from left to right and wont print
    The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
    The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
    The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
    If you cannot repair the strip, please let us know so that we can assist you further.
    Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
    May 28, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
    Hardware error 0502 and error code 50c
    Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. Lexmark will replace the printer, only if it is under warranty.
    Apr 26, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Cant put printer piece back in
    Try to print any document.
    If this failed then printer cannot be repaired, if the printer is under warranty then Lexmark will replace the printer else. I am sorry to say you need to purchase a new printer
    your's tech expert
    Jeeth
    Mar 28, 2009 | Lexmark X1270 All-In-One InkJet Printer
    Ink cartridge has stalled
    where i can buy printer lexmark model Z640 i look on Ebay and local store but no one carry them.
    Thanks
    Oct 31, 2008 | Lexmark X1150 All-In-One InkJet Printer
    Error 1200
    Lexmark X4270 Error 1200 Fix - Click here for document link
    1. Unplug printer from wall and remove power supply.
    2. Unplug any phone lines or USB cords connected.
    3. Remove printer attachments, paper trays and phone.
    Figure 1 - Printer paper holder and completed print tray
    4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
    Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
    5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
    Figure 3 - Top view of printer showing which screws to remove.
    5. Cont…
    Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
    6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
    7. Remove the ink cartridges out of their carriage.
    Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
    Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
    NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
    Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
    8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
    9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
    10. Unplug the X4270 and remove power supply.
    11. Remove bottom assembly carefully.
    Figure 8 - Displays bottom assembly with lever and spring
    Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
    Figure 9 - Displays loop attachment
    12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
    Figure 10 - Displays fix for jammed carriage.
    13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
    14. Plug in and check if operational.
    15. Reassemble X4270 using steps 3-7.
    Oct 03, 2006 | Lexmark X4270 All-In-One InkJet Printer
    Lexmark X1270 All-In-One InkJet Printer Logo
    203 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
