Question about HP PSC 2355 All-In-One InkJet Printer
Error 0xb9000009 165hw interrupt hwv2.c is the error i'm getting. New cartiages. not used often though.
How to avoid the worse cartidges
Check printer cartridge compatibility before unpacking a new print cartridge. Make sure that it is compatible with your printer.
If it is not compatible then it can give error ...........
If you need any kind of technical assistance on printer support then call at-http://www.vtechsquad.com
Aug 30, 2012 | Canon MP270 All-In-One InkJet Printer
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart 8250All-in-One System Failure) I refer to printer documentation Error:0xc18a0001 Turn power off, then on again. I dId this command but...
Try taking out the cartridges, and turning off then unplugging the printer. Leave it unplugged for about five minutes, the plug it in. Wait a few more minutes, and turn it on. Wait for it to completely start up, then put the cartridges back in (make sure you are putting them in correctly, I think this is your product here). If it still shows the error, contact HP customer service. They will probably say something similar, though.
Jul 06, 2011 | Office Equipment & Supplies
Moved and plugged in printer and it won't wax. I get a message remove and check cartiages. Relpaced cartiages and still won't clear the error message. please advise... leener_hines@yahoo.com or post. ...
Hi
if you have replace with new ones and you still
get that error
try cleaning cartridge carrier with a paper towel
if nothing is happening
you need to take it to an Hp support point
near to you
if i helped you pls vote
Sep 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Out of toner U13 Error Massage display continuous.
are you using the original cartiage,if yes chek the toner moter
Mar 15, 2009 | Panasonic WORKiO DP-8016 Printer
My hP deskjet F4288 shows ERROR symbol
I would remove the refill. HP voids the warranty if the cartridge leaks. I have seen refills leak and destroy the printer. Replace with a brand new cartridge. If that is not the solution you want. You can remove the cartridge and clean it with rubbing alchohol and a paper towel or a q-tip, just make sure there is no fuzz left when your done. Also if you have the HP software installed on your computer, there is usually a cleaning program built into the software.
Mar 14, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Printer cartiage error
This page may help.  One of the things it's supposed to help with is 'cartridge error'.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00094661&dlc=en&product=374581
If that doesn't help, can you provide more detail about the cartridge error message?
Dec 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
In pop up window it tells me colour cartridge error remove and check which i have done to no avail. also on comp screen tells me cart error. Have tried to press set up nothing happens. Also have a red...
Make sure the cartiages are sitting tightly in the printer and isn't loose. There are contacts on the cartiages and if the contacts aren't touching the ones properly in the printer it will show that cartiages aren't there.
Aug 21, 2008 | HP Office Equipment & Supplies
Sharp al1217
I've never seen this model in Australia but could you confirm if its drum or toner either way its just the machine letting you know that it needs changing soon, however we have other models that do the same and run for quite a while before the quality drops off
Mar 18, 2008 | Sharp AL-1217 Copier
I had the same problem too. Brand new unit and 5100 error comes on after power up. There is nothing jaming the ink cartiage, and it only moves a little bit to the left then jams back to the right. I can't even load in new ink cartiages. It's going back to the shop today.
Apr 23, 2007 | Canon PIXMA MP170 All-In-One InkJet...
HP PSC 2355 All-In-One InkJet Printer Logo
672 people viewed this question
Seeker5211
Seeker5211
