I have a Hitachi CP-S317 data projector that has been shutting off every 10-15 minutes. I replaced the lamp, cleaned the air filter, and reset both timers. When I power the projector on, it comes on, but does not project any light through the lens. Except for no light, it runs normally for about a minute and then seems to cycle into what I can only describe as "hifgh gear" before it shuts off, leaving the power and lamp buttons a red color. Any help would be appreciated.
  • 442 Answers
It seems that the lamp ballast unit is not striking the lamp, or the new lamp is no good.
Try using the old lamp as a test to see if it comes on at all.
Posted on Apr 08, 2011
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
My Hitachi cp x250 projector powers on and displays and then the bulb turns off after a few minutes, and the lamp light and the power light come on red.
Most likely you have a defective lamp or it is near the end of its life. It's also possible that the high voltage power supply is going out. You might check the lamp hours - you can find this in the advanced menu. Also check the air filter, if you haven't cleaned it, the airflow might be restricted, shutting down the projector.
Sep 18, 2009 | Hitachi CP-X250 Multimedia Projector
Problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Mar 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
Cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Feb 01, 2009 | Hitachi CP-X445 Multimedia Projector
Hitachi cp-rs55 not working,tic.tic.... noise coming from project
make sure you reset the lamp timer. Manual has the steps. Hitachi Performa CP RS55 3 LCD Projector
if the timer is reset, try cleaning the color wheel. Optoma HD20 Projector Cleaning this video is for an optoma but the color wheel is cleaned the same way in most DLP projectors. Dirty or dusty color wheel sensors cause the projector to shut down and act like its the lamp.
Feb 02, 2018 | Hitachi Performa CP-RS55 Multimedia...
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Hitachi CP-X960 Shutting Down
Hi Jason
This is normally a faulty Ballast ( lamp's powersupply )
It will need replacement unfortunatelly
Apr 02, 2008 | Hitachi CP-X960 Multimedia Projector
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
74 people viewed this question
k24674
jasbo
jasbo
