Question about Samsung Washing Machines
My Samsung B1415j Big wash is giving E2,water does not want to drain and door does not want to open. Thanks Jaco van Rensburg
2 Suggested Answers
  • 6277 Answers
SOURCE: I have a samsung Big
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 10, 2011
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
I have a samsung Big Wash b1415j. The water is not draining error code E2 What can be the problem
John C
Aug 10, 2011 | Samsung Washing Machines
Have an E2 code on my Samsung washer and can't open the door... have tried to go through the rince again [8 minutes] but that didn't seem to help.. and so, HELP please
if there is still water in the washer then you can use awet dry shop vac and attach it to the end of the drain hose to remove the water. once the water is gone then you will be able to open the door.after that then you will need to check the drain hose for any obstuctions in the hoses or the drain pump itself
Nov 21, 2010 | Samsung Dishwashers
Samsung washer front load willnot rinse - no water coming out of hose to drain. E2 shows up
Hello,It is drain pump error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Thanks
May 31, 2010 | Samsung WF337AA Front Load Washer
Samsung b1215j code e2 lights up. any clues,
Lo M8
E2 code means it's not draining out the water properly
so look for a blockage at the pump
turn the power off to the machine
take the front bottom plastic cover off so you can access
the drain tube front right small plastic plug bout 13mm in size
get some towels and a shallow tray to catch the water
remove the small plug and drain the water ( takes age by the way )
once you've done that put the small plug back in
and then unscrew the black plastic ( they come in several colours )
pump access plug bout 50mm in size which is just to the left
of the drain tube ,, there may be a small amount of water left
in the pump but it won't be much
Once the pump access plug is removed look inside the hole
and see if you can see anything stuck in there most often
it's coins or other junk thats been left in pockets or very often
if you've kids it's going to be socks or other small clothing items
which have been sucked in to the pump
remove any blockages refit the pucp access plug
turn on the machine and put it thru a quick wash cycle
make sure it drains and spins out !!!! if not then repeat the above
procedure as you've got something else still stuck in there
good luck
Spiidi
Dec 16, 2009 | Samsung Washing Machines
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Does not drain water and door does not open
Fault code E2 refers to a clogged drain pump.The drain pump needs to be cleared from kinks.Sometimes replaced if damaged due to the clogs.Please provide me the model number so that I can get more info regarding this and can provide you with some internal diagrams which will make it easy for you to locate the drain pump.
Good luck with the machine.Please do rate my solution if accepted.
Apr 11, 2009 | Samsung Washing Machines
Error E2
It is drain pum error. Possible solution:
Good Luck
Jan 08, 2009 | Washing Machines
Samsung bigwash washing machine b1415j
on the front of the machine at the bottom is a panel you can take off to clean the filter. take this off and there is a plastic cord you pull to release the door! hey presto
Oct 23, 2008 | Washing Machines
Washing Machines Logo
107 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
