Question about Car Audio & Video
I've a problem with my car dvd players alphavision model wf1189 i wont to recalibrate it
Why em808vid touch pad is not response?
I've similar question. My ipod touch 2 screen is very finicky! It sometime responds just fine, but other times requires multiple taps before it does it's duty. Is there a fix for this? I have tried soft resets and recalibrating. The recalibration works fine, but I don't think it should have to be done daily which is about what I'm doing now. Is there another more permanent fix for this problem?
Aug 13, 2012 | Ematic 8GB Flash MP3 Player EM808VID with...
Dvd draw wont open without the remote
VCR combo?? I had to check the date on this post to see if it was from 1990. Do you still view VCR recordings? If not, then trash it and get a DVD player. I've seen them for less than $20 new.
Jun 21, 2012 | LG V181 DVD Player/VCR
My LG RH397D HDD wont recognise dvds any more
The only thing you can do is try a DVD cleaning kit and follow instructions, if that fails the laser pickup assembly will need to be replaced, but this would be to expensive and far cheaper to replace the player.
Mar 27, 2012 | LG Televison & Video
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
Que hacer cuando pongo un dvd y no c ve ,me aparece una texto en ingles?
cuando los dvds no se ven en algunos DVD player especialmente de caro es porque ese DVD player no es compatible con ciertos DVD players
Oct 21, 2010 | Audiovox VM9512 Car DVD Player
Dvd player freezing up and wont finish a burned dvd?
I ve got the same problem as well.. its due 2 damaged lens.. u shud try cleaning up ur lens from a lens cleaning CD available in market or a better option is give ur DVD player for servicing..
Nov 11, 2009 | HP Media Center Photosmart PC (M7160N) PC...
Jensen model vm 9510
tienes que quitarle los alambres del emergency break y connectarlo con cualquier tierra.Luego asi lla va a salir el dvd o lo que sea.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
GPS touch screen not working
This works!!!! This saved me $200.00 I am eternally thankful! the key to it is pressing the little reset button. it is very small and only accessable with a pen. If you follow the directions as listed, it will work. I've been born agan for fixya!
Jul 30, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Recalibrating touch screen
Use the pin hole reset button.
Oct 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Car Audio & Video Logo
117 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
