Question about Ricoh Office Equipment & Supplies
We have a Ricoh Aficio 2022 and everytime we try to print, it stops and indicates a jam on the right side. We open everything up, can't find any jam, close everything up, it re-sets and then does the same thing when we try to print. Yesterday there actually was a jammed piece of paper but we got all parts out and it still won't make copies.
  • 263 Answers
Try clean the feed roller.
Probably your feed roller is not piking the paper and gives you a message of paper jam.
You can clean it or change it.
Posted on Apr 06, 2011
How to get ricoh aficio 2022 usage
Counter? If you are looking for the counter page press the button with a diamond shape and a 123 icon on it. There you will see a counter, press ok and print and the green button!
Jul 16, 2014 | Ricoh Aficio 2022 Black and White Copier
I have a ricoh aficio 2022 and the problem is that sow error j001 jam at the c section but there is no paper stuck on the printer
first is clean the sensors especially the exit sensor, check also the door switches maybe they are not functioning well so the jam will not be reset
Jan 22, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
I HAVE A COPIER RICOH AFICIO 2022 SP WITH THE CODE SP 545 BUT I WANT TO KNOW WHERE IS THE THERMISTORS TO CLEAN IT
Thermistor is in the fuser. Open right cover and you see the fuser. On a fuser have some labels "Hot Surface" "Danger... or something
Jan 24, 2011 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Hi, we cannot print to the Ricoh Aficio 2022. I have connected to the printer by pinging the IP address of it and it is OK. The 2022 can still photocopy. I have tried a test page and nothing prints.
Are you sure no other device on your network has the same IP address? (Turn the copier off and trying pinging that IP address to make sure.)
Do you have the Ricoh 2022 driver installed? You can download it from Ricoh-USA.com if you don't have it.
Aug 23, 2010 | Ricoh Aficio 2022 Black and White Copier
SC 548 on ricoh aficio 2022
Hi Andreas: The fusing unit has not been reinstalled properly. There is a receptical on the back of the Fuser that mates with a plug in the machine when you install the part. the machine is telling you it did not detect the fuser. Undo the screws and remove it and reinset it again, makin sure that it seats properly. then you will need to reset the code. Go into SP Mode: Push in sequence; Clear-107-red stop button(hold this down until display changes and shows "copy etc"), turn machine off(using red power switch, wait 10seconds and turn back on. If you still get the error code the fuser still is not inserted correctly. Hope this helps.
PS: Black spots can also indicate a new drum is needed. It may have a small chip in the surface.
Regards
Munybuny
Jan 22, 2009 | Ricoh Aficio 2022 Black and White Copier
Add Toner
pull out hopper and remove bung of old tube from inside!.
Feb 08, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
194 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
