Question about Fargo DTC525 ID Card Printer
Is there a fargo certified service center in the Seattle or surrounding areas?
I have a DTC525 printer that needs service. It keeps breaking ribbons, every time it tries to print, and unless I tuirn the heat settings way up, there are washed out areas on the cards or test cards. Also I may have a single blown pixel, and need more cleaning tapes. I really would prefer a local shop to avoid sending the printer through a costly shipper, andd also to avoid too much delay in its return.
    Problem Solver:
  • 10 Answers
You could look at Fargo website www.fargo.com to find service center neer you or call customer service they will help you Number on website
Posted on Sep 16, 2009
Which tipe of ribbon to be used in DTC525
hello
http://www.idsuperstore.com/fargo-printer-ribbons-fargo-dtc525lc-ribbons-c-5_79_1472.html
try this link for your ribbon printers
thanks
Mar 03, 2011 | Fargo DTC525 ID Card Printer
Anytime she goes to print a badge the ribbon breaks. It's the correct ribon. She's put in a new ribon and the same thing happens.
When the ribbon keeps breaking on fargo DTC300 or any similar models (the ones that share similar mechanics) three steps are to be taken.
1- Verify, clean, calibrate or replace the ribbon sensor (maybe you'll see an error like "Panel Searching" that means " the ribbon sensor can't read the ribbon panels normally).
2- Clean the "card path" (the feed and platen rollers) for dust dirt and debris using the manufacturer's cleaning kit (or a clean
lint-free cloth with isopropyl alcohol) and the "clean printer" option.
3- Clean the inside and outside of the printer (pay attention to the printhead) with dust-off, lint-free cloth, isipropyl alcohol and enjoy.
Or, for more advanced ts take it to a certified tech!
Mar 02, 2011 | Fargo DTC-300 Thermal Card Printer
Ribbion keeps breaking
locate the tension ribbon and - it
Dec 03, 2010 | Fargo DTC525 ID Card Printer
Fargo HDP5000 HDP5k H5k Ribbon Breaks Error 97
You need to update the printers firmware. 9 times out of 10, this is the issues I see.
Go to HIDglobal.com. Under the support tab, select Drivers & Downloads. From here, populate the drop down menus with Make and Model. Compare the available firmware with the firmware version current installed on the printer.
Hit [Options] then [Next] on the printer to figure out the version.
On this same web page, make sure to download the Fargo Workbench Utility. It gives you the ability to update.
Aug 06, 2009 | Fargo HDP5000 Thermal Printer
Printer keeps breaking the ribbon
first, try to calibrate the ribbon, if it does not work, you probably have worn out rollers, and possibly a broken o-ring. if you want more info, call us at 310-671-8018, thanks adi
Mar 25, 2009 | Fargo DTC400 ID Card Printer Package
Problem on card print using Fargo DTC525 Single Side Print model
you can check with fargo, or perhaps your vendor is giving you the bad rep, since they refuse to help you. i would not do business with them again.
if the printer worked before maybe the program needs to be reinstalled.
Jun 10, 2008 | Fargo DTC525 ID Card Printer
Front Panal button not Functioning
It sounds as if your front panel control is not working. You need to contact a solutions provider in your area for a service call.
For technical assistance by blog, visit our id card printer support at www.safecardid.com/blog.
Dec 31, 2007 | Fargo DTC525 ID Card Printer
Breaking since I change printhead
Hi, i think you must to adjust tension of ribbon.Go to menu and find adjustmento for tension,and try to adjust to "-" or "+" value, in small increaments.Print card and if no results,try again.
BR
Dec 05, 2007 | Fargo DTC525 ID Card Printer
Breaking Ribbon
Ribbon breaking continuously is caused by 2 common problems. 1. The printhead is going down before OR after the card has passed through. You would know this when you open your cover, and unlock you printhead, is the break before or after the card? Try printing the test page from the driver. That doesn't print "Edge to Edge" so if this is the problem, it should not break. 2. The print head heat settings are too high. If this is so, you can change this on the printers menu panel. I can explain more information, once I know your problem.
Jan 15, 2007 | Fargo DTC525 ID Card Printer
Fargo DTC525 ID Card Printer Logo
161 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
