Re: worcester bosch heatslave 20/25 model lockout light is on, i have checked oil and water pressure and both are ok. tried to reset but locks out again after a few minutes.
  • Anonymous Sep 26, 2008
    went away on hols for a week so turned the program off but left power to the boiler, got back put the programmer on and after 2-3 mins it locked out, reset it a few times with no joy, called local plumber out, he didnt really know what was wrong but noticed that when he took the top off there may have been a long term weeping affecting a circuit board? he said it may be expensive (always is) has anyone else had to have this circuit board replaced??
Air in Oil line, Blead air out.
Posted on Aug 25, 2008
SOURCE:
Greenstar heatslave 9f 855 error code any body?
It is a burner lockout. Have you checked your oil level?
Jan 07, 2014 | Water Heaters
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Worcester heatslave 9.24 pilot light wont stay lit, pressure is o.k. what is the part and where do I get it (thermal coupling?)
thermocouple any plumbing or heating shop juast ask for a universal thermocouple ie honeywell the heating shop willl know what you will need
Apr 13, 2010 | Heating & Cooling
Constantly locking out
overheat stat or fan best of luck
Jan 10, 2009 | Water Heaters
Worcester bosch high flow 400 lost pressure put up pressure
There are two small brown reset buttons under the control panel. Take off the white front cover and you will see them.
Nov 23, 2008 | Ruud Matching Split Air Conditioner
Worcester heatslave 26/32 pressure too high and water coming out overflow
? so was my response any help? - if so please rate me thanks- I did this for 21 years -so it should help. Al
Oct 19, 2008 | Water Heaters
Heating & Cooling Logo
2,050 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
