Question about RF425LCD 4 Channel Keyless Entry Car Alarm w2Way Remote
I feel like my sensitivity for my autopage alarm for my car is not set high at all i have pushed the car and even sat my hand on the hood and the sensor does not make a noise stating that it is detecting someone messing with the car.. please can can i do so basically how can i adjust the sensitivity of the alarm with out doing back to the people that installed it
4 Suggested Answers
  • 7 Answers
SOURCE: i have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
Posted on Jul 16, 2010
emissionwiz
  • 76109 Answers
SOURCE: where is the relay system on a car alarm
it is a standard bosch style relay, it should be under the dash on left or right of the steering cloumn
Posted on Sep 11, 2009
guru_fixya
  • 944 Answers
SOURCE: i just got an autopage
Please read paragraph L in the below pdf for proper settings.
http://remotelystartedmn.com/files/starter-manuals/RS-730LCD.pdf
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 10, 2011
MY CAR ALARM KEEPS GOING OFF FOR NO REASON
Your car alarm has a sensitivity setting if the sensitivity is too high it will set off the alarm if the wind blows too hard or a heavy vehicle drives by in close proximity turning down the sensitivity will solve this problem
Nov 18, 2015 | Cars & Trucks
Security alarm goes off every 15 minutes for no apparent reason
Hi Gregg, Im AL the owner of Big As Auto Repair
Gregg, several things can cause a car alarm to go off. One of the most common reasons is the alarm switches which are mounted to doors. under hood, trunk. When these switches go bad OR get corroded from water, can cause the alarm to go off with just the blowing of the wind moving the car. Check this by pushing on each door and see if the alarm goes off. Also push downward on the hood and trunk. Even door adjustments can cause the issue, because if a door is not tight it can move and set the alarm off. One other thing is sensitivity, the alarm box can be going bad and the slightest movement of the vehicle can set it off. Check out my auto-repair website and the testimonials: http://www.bigasautorepair.com/
Jul 06, 2015 | Cars & Trucks
How do I reserve battery life on my autopage alarm key pad model XT-73LCD
If you put remote in your pocket or your purse make sure it doesn't push on any buttons!
Mar 30, 2014 | C3RS915 SST Remote Car Start Vehicle...
Car alarm keeps going off
Check your fuses. If it's an aftermarket alarm, it should have it's own fusebox. Just follow the wires from the alarm itself and you should run right into it. What kind of alarm is it? If it's not the fuse, then you have a short somewhere in the wires, or the sensitivity is set too high and I've had a problem with a motorcycle alarm where the sensitivity was set too high and a gust of wind would set it off.
Aug 03, 2013 | Cars & Trucks
My autopage rs 727 lcd is not starting in remote start, it is only cranking
what kind of vehicle? it is most likely a transponder or theft system bypass problem, since it is trying to crank.
Feb 12, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
Why does the alarm in my car go off when I try to start it with the remote car starter?
If this is the vehicle's factory alarm that is being triggered then your factory alarm must be disarmed prior to the remote starter sequence. The Autopage unit has a factory disarm wire available for this purpose. When the alarm triggers again try turning the key in the driver's door to see if there is a factory disarm wire available in the vehicle or if the factory alarm is RF disarm only. If it is the after market alarm that is being triggered then you made need to decrease the sensitivity.
Nov 23, 2010 | C3RS727LCD 4Channel Alarm with Remote Car...
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
Over sensitive car alarm
at the control module under the hood usually there will be a know or a screw of sorts to adjust sensitivity
May 01, 2009 | 2006 Ford F-150
RF425LCD 4 Channel Keyless Entry Car Alarm w2Way Remote Logo
160 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
