I need to remove the top lid of my Kenmore washer, model 110.20842.990, in order to replace the lid switch. I do not have a manual or diagram that shows the steps to accomplish this. Can you help?
  • 5,911 Answers
In order to access the lid switch, you will need to remove the exterior washer case. The following link explains how:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have questions about any of these steps, please post back and let me know. I hope this helps you.
Posted on Apr 06, 2011
My Kenmore washer will fill with water and oscilate, then nothingf won't spin or drain. I 'm guessing that it is the lid switch , ( relay switch ) ?? Mod # 110.94518201 serial # VLG 1601709 can this...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11094518201/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Look at the diagrams for the cabinet and you'll see a list of component parts (Lid Switch) with the Sears part numbers (the manufacturer authorized substitute numbers are Whirlpool) and the Sears price.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Dec 03, 2010 | Washing Machines
MODEL 110-24722300 KENMORE WASHER. LID SWITCH DOES NOT WORK AND HAS COME LOOSE. HOW DO I PUT IT BACK TOGETHER?
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024722300/0582/0153200?pathTaken=
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet. See the Sears diagrams on the control panel and cabinet to see where / how the switch connects.
Nov 24, 2010 | Kenmore 22422 Top Load Washer
My kenmore ultra fabric care heavy duty 80 series model 110 will not drain. The problem occured after a heavy load knocked the lid switch off during the spin cycle. How do i fix this/replace the lid...
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Nov 05, 2010 | Kenmore 24032\24036 Top Load Washer
I have lid swich broken in my washer. the model no.11024692300, company is kenmore. can u please send me the discription with written & picture manual to how to fix it....thanks
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24692300&pathTaken=partSearch
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
I have a 9 year old kenmore washer that just stops
Jun 22, 2010 | Kenmore Washing Machines
My mom has a Kenmore washer model# 13212200. It has been sitting unused for 4 years. I ran the machine to make sure all was working and all was fine until it got to the rinse/spin cycle. It would not...
If the washer fills normally, begins the wash cycle, then stops at the spin cycle and won't drain, then you need to check your lid switch and/or lid strike. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. The part number for a replacement switch for the model number you provided is 3949247. The lid strike (also called an "actuator') part number is 350733.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Jun 11, 2010 | Kenmore Washing Machines
The washer lid has to be slammed in order to work
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If it works, the Lid Switch is a relatively inexpensive part.
Apr 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
Need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Sep 18, 2008 | Kenmore 22422 Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
