Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
I think the green is out. No matter how we play with the settings we cannot get any green to show in the pictures. What can we do to fix it? this is a JVC av 56p575
  • JVC Master
  • 11,800 Answers
This is a CRT projection monitor - the image is generated by 3 separate tubes. If the green colour is missing then either the tube has failed or the video circuit to the green tube is faulty.
You must find out which by measuring the voltages on the green tube - if they are ok then you will need a new tube. You could find one here - not at this moment, only a blue one is available now
http://www.partstore.com/Model/Matsushita/JVC/AV56P575.aspx?p=1&z=50&c=256d4ef3182019bb69503a824cf22601&bs=Category&bd=Asc&ms=Price&md=Desc&k=&on=&cfilt=#1
Posted on Apr 06, 2011
My camera sony DSC-55 shows a pink background and after I take a picture everything looks pink and green
You have a problem it seems with the circuitry of the camera. This camera is too old for warranty, so I would suggest to try to set the menus to original or factory settings. Then test it.
If that does not fix the problem, do some testing further. Get a card from another camera and play it back on this one. If the picture is good, then the problem is in the ccd to the circuit system. If you can see the menus with the correct colors, then suspect ccd sensor. If the bad colors are always there, then you can suspect a few things, one, the LCD could have bad connections or is bad otherwise. If you see any good colors from the menus or playback, then that part of the camera is probably good. And there could be bad or failing parts in the circuits if colors are always bad no matter how you test it.
Apr 15, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I have a tv that only shows variations of blue and yellow no matter what i do to the menu color options. However the menu will show all of the colors but not the normal screen.
it sounds like an rgb problem it depends what your playing thru your tv but if its coming thru a component lead eg red green and blue it sounds like your missing the red feature also it could be a pin bent on your scart which is carring the red portion of the picture , What kind of set is it and what are you playing thru it ?
Mar 02, 2010 | Akai LCT2060 Television
My camera does not show what i have taped
Regarding no picture in playback is problem mostly of dirty / clogged video head in Sony handy-cam and can be corrected by using good quality video head cleaning tape.
As far as memory stick picture concern, I think lost pictures (42)would be in other folder on memory stick.
Jan 12, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Green tint to picture when dvi cable is connected
The tv will show correctly in 720p mode. Cable box and PS3 must be set to display in 720p or the green tint will remain. For the PS3 I return it to 1080p when I am about to play a game, blu-rays and dvd's can only play in 720p.
Dec 15, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
Samsung Monitor Syncmaster 913V Montior Screen shows patches of screen on desktop and playing videos
Sounds like your LCD panel has gone bad.
If the unit is under warranty, take it to a Samsung repair shop. If it is not under warranty, go buy a new one. LCD panels are usually more expensive then buying a whole new monitor.
Mar 21, 2008 | Westinghouse L1975NW Monitor
Green lines across screen
check these components in the Video out, IC7101, 7201, 7301 and others in C
board circuit.
Q510,516,524 (A board)
if they are good then the picture tubes would need to be replaced, but since they are no longer available it realy wouldn't matter much would it.
Feb 13, 2008 | Sony KP-65XBR10W 65" Rear Projection...
WD-52525 too much green and picture is not clear...what can i do to fix it
. Suspect the FMT PCB part # 930B924002. Supect the DM PCB part # 934C116002 if green tint
Aug 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
