Question about Boss AUDIO SYSTEMS BV8220 Car DVD Player
The screen on my stereo boss bv8220 went black . everything works except the screen it no longer lights up. what could be the problem and how do i fix it
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
Dead laptop
Video card probelm. First see if the video card is not loose. Check the Bios to see that that display is enabled.
Jun 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
New radio installed - now dash lights don't work
Most factory stereos are wired to the dash dimmer switch. Usually if the dash lights go out after an after market stereo installation, it is because the wire that originally went to the factory stereo is not used for after market stereos. Double check the fuses and ensure the wire that controlled the lights on the factory stereo is not grounding out on something.
Nov 11, 2008 | 1998 Honda Passport
Subwoofer blew up my car stereo
You didn't mention an amplifier. Did you try to connect your subwoofers directly to your head unit? If so, that is why you no longer have a working head unit, unfortunately. You have to have an external amplifier to drive those subwoofer, not 22 watts per channel from an in dash stereo. You're correct in your assessment that putting the subs in again would cause the same thing. Find a reputable shop that can sell you and properly install the equipment you need to get you up and running again. Sorry for your loss.
Jun 27, 2017 | Car Audio & Video
The screen went black
take the phone and ahve the LCD replaced
Jun 20, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Boss AUDIO SYSTEMS BV8220 Car DVD Player Logo
54 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
