Question about Microwave Ovens
I have a Cuisinart hand mixer - HTM 9LT SMARTPOWER COUNT UP 9 SPEED ELECTRONIC. I think that I used a speed that was too high while mixing a thick icing because something seemed to slip and the beaters stopped rotating. The motor runs and I can insert the beaters but there is no engagement. I know that small appliance repair is expensive so I'd like to try to repair/replace any part that I damaged - if that is possible. The sound that the mixer makes reminds me of the sound of a vacuum cleaner that has a damaged belt. There are no visible screws that connect the bottom to the top of the mixer. I tried to pry them apart at the seam but only succeeded in putting a small crack near the back :( What to do??
gwshaw71
  • 83 Answers
SOURCE: bottom screw on handle loose
open the door and you will have to peel and pry apart door.It is abot a 1-2" frame around inside door.that peels off it just snaps in.
Posted on Nov 25, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: OTR microwave turntable won't rotate
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If not, please post your brand and model.
It's probably the motor, but possibly the coupler.
One quick check is to remove the turntable and support / roller ring and try to turn the coupler. It should be a little hard to get started, then you should hear a whirring sound, not a clicking or grinding, which would indicate a bad motor.
If the coupler turns loosely with no resistance, then it's probably bad.
Here is my text on replacing couplers, which had steps which are necessary when replacing motors. Note that if yours is a built-in model, ignore the part about turning it on its side *grin*
NOTES ON REPLACING TURNTABLE COUPLERS
Copyright 2007 by William E. Miller - MicrowaveDisplay.com
UNPLUG THE OVEN FROM THE WALL FIRST OR YOU WILL EXPOSE YOURSELF TO LETHAL VOLTAGES!
Note that I am not encouraging you to work on electrical items if you are not qualified, and I assume no liability for any consequences of your decision to do so.
When replacing the turntable coupler on most models, it is necessary to loosen or remove the screws that mount the turntable motor to the bottom of the chassis.
It is usually easier to do this with the microwave oven on its right (heaviest) side because you will need two hands for alignment.
Be sure to put a towel or similar cushion on the work surface to avoid scratching the oven wrapper (oven cover) or the work surface.
It is not necessary to remove the wrapper or the wires from the turntable motor itself, but you may need to remove a small metal duct covering the turntable motor if your oven has one.
It should only be held on by one or two screws.
Although a broken coupler may come out easily or even fall out, the new coupler will not go in without at least loosening the turntable motor.
Look at the hole in the new coupler. You'll notice it has (most do have) a flat side to it. That flat side will line up with the flat side on the motor shaft.
When the old coupler is out and the motor is loose, you can ease the new coupler in the hole with one hand while turning the coupler very slightly back and forth as you gently push the motor toward it. Do not force the part in.
When the coupler has mated properly with the motor, you should feel it go in.
Be sure it's right, or you may break the new coupler or bend the mounting ears of the motor when you attempt to tighten the screws.
Reassemble in reverse order.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
SOURCE: Door Disassembly
Drilling a little hole from the inside-out and putting a little screw did the job in 10 minutes. Awesome recommendation. Thanks.
Posted on Jan 27, 2008
  • 65 Answers
SOURCE: Replacing door handle???????
gently pry the plastic from the inside working from the hinges to the corner. you will need to put something in place of the screwdriver when you pull it out to go to the next pry position (about every 2 inches. i use apex bits. you can use anything about the diameter of a cigarette. then the screws for the handle will be exposed . it all snaps back together.
Posted on Feb 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JVM1870SK03 won't heat food, hums and puts out a burning smell
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more and is more complicated to replace.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it needs a new magnetron, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If you want to contact GE about having an authorized servicer look at it, or have them send you a magnetron, GE Customer Service is here.
Posted on Dec 07, 2008
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a cuisinart ccm-16pc coffee grinder. I need a couple of parts, namely the grinding wheel (that's attached to the motor) and the plastic gromet (for lack of a better word) that fits on top of the...
For future reference the Manual for the DBM-8 is here:
http://www.cuisinart.com/share/pdf/manuals/dbm-8.pdf
Available parts:
http://www.cuisinart.com/parts/coffee_bar/dbm-8.html
Here is another site for parts; they do not list what you are looking for but you can make an on-line inquiry for parts.
http://www.abtecparts.com/cuisinart_grinder_DBM8C.htm
Parts Inquiry:
http://www.abtecparts.com/parts_enquiry.htm
Unlike many appliance makers Cuisinart does not have an on-line search function for service centers. If they could not name one you might try contacting some small appliance repair shops; if not able to help they may be able to direct you.
Feb 13, 2011 | Microwave Ovens
The microwave will count down the time but is not heating. There are two icons flashing above the time, and I don't remember seeing this before.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Feb 12, 2011 | Cuisinart CMW-100 Microwave Oven
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
Good Day, One of the beater ends broke off my BC1206cr Betty Crocker hand mixer while mixing cream. The other one is loose as well. Can these be replaced? Where do I purchase them or is there a...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | Microwave Ovens
I have a Braun Kitchen Mixer KM32. I have had it for several years and like its capabilities. Now I find that the bakelite backing and speed control to the switch has dried out and has broken-up. Where can...
Braun KM32B Mixer is made in Germany long time ago.
You can buy a switch at:
http://www.californiaelectricservice.com/braun_km32_mixer_series_parts.asp
for $8.99, it does not fit, but still can use it as an external switch, in a small electric box.
Sep 04, 2010 | Microwave Ovens
ON CHRISTMAS AS I MIXED A CAKE MY KITCHENAID MIXER SOUNDED LIKE IT WAS STRUGGLING, THEN IT JUST STOPPED RUNNING. MY MIXER IS LESS THAN 5 YEARS OLD AND REALLY HASN'T BEEN USED VERY MUCH. PLEASE TELL ME WHAT...
Is the warranty still valid?
Is there a recall on the model you have?
Typically the problem you describe is a problem with the motor brushes or you were mixing more material than the mixer was designed to mix and the internal thermal link failed.
The mixer is too young to develop this problem without abuse of a material flaw.
If there is no recall on it and the warranty has expired your best bet is to buy a new mixer. Repair cost will typically exceed the cost of a new on if it was a cheap model costing less than $50.00.
Jan 06, 2009 | Microwave Ovens
Microwave Ovens Logo
82 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
