Question about Canon imageRUNNER C3200 Copier
I am hoping there is a product which will allow us to clean the inside of the machine. I am thinking the problem might be with rollers as there are 3 black streaks across the page horzontally.
    New Friend:
  • 140 Answers
You have to replace either drum unit or intermadiate transfer belt which call ITB.
Posted on Apr 07, 2011
How do i clean the gray roller inside?
the grey roller (1"wide) can be cleaned using Spray WD40 on a cloth, wipe the roller clean using the chemicals in WD40,(also moisturizes the rubber) allow 5 FULL mins for evaporation then wipe ANY excess off with a CLEAN DRY cloth, first few feeding attempts may faail leaving residue this is normal.alternatively use a professional rubber restorer compund.
the long Grey roller spanning the entire print width is Not removable, it is factory fitted and set into place, stripping a machine down to that level is not cost effective even at very low labour rates.
Mar 11, 2014 | HP Deskjet 3510 e-All-in-One Printer
Once I turn my printer psc 2410 photosmart on it makes an annoying sound like if something is stucked and freezes staying on the clock sand mode . What should i do?
During printing, the HP product makes unusual or loud noises. You might describe the noise as grinding, squeaking, or screeching.
    Step one: Clean the rollers in the back of the product
    1. Disconnect the power cord from the back of the product.
    2. On the back of the product, find the rear door.
    3. Squeeze the tab or tabs on the rear door, and then pull the rear door toward you to remove it.
    4. Open the rear door on newer Photosmart, Officejet, or PSC productsInside the back of the product, rotate the paper rollers with your fingers to make sure that they can turn freely.
    5. Rotate the rollers located on the inside of the rear door to make sure that they can turn freely.
    6. Remove any torn pieces or scraps of paper that you can see.
    7. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe the paper rollers inside the product and on the inside of the rear door clean. Rotate the paper rollers with your fingers to clean all the way around them.
    8. Reattach the rear door. Make sure that it snaps into place.
    Step two: Clean the rollers in the front of the product
    1. Lift the cartridge access door to access the front paper rollers in the product.
      NOTE: On some Officejet models, you might need to close the document catcher. Then, look in through the front of the product to access the front paper rollers.
    2. Inside the front of the product, rotate the paper rollers with your fingers to make sure that they can turn freely.
    3. Remove any torn pieces or scraps of paper that you can see.
    4. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe the paper rollers clean. Rotate the paper rollers with your fingers to clean all the way around them.
    Step three: Clean the small rollers Dampen a clean, lint-free cloth or swab with distilled water, and then wipe the small rollers, also called the pinch rollers, clean. The pinch rollers are the small metal rollers directly above the paper rollers. Rotate the pinch rollers with your fingers to clean all the way around them.
    NOTE: Do not clean the carriage rod. Removing or damaging the lubrication on the carriage rod can cause the product to make more noise. Figure 9: Carriage rodc02203348.jpg Step four: Clean the cartridges
    1. Connect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
    2. Open the cartridge access door. Figure 11: Lift the cartridge access door on newer Officejet, Photosmart, and PSC productsc01940403.gif
    3. When the carriage stops moving, disconnect the power cord from the back of the product.
    4. Press down on each cartridge to release it from the carriage, and then pull it toward you out of its slot.
      NOTE: You might need to lift a cartridge latch before you can remove the cartridge from the product. Press down on each cartridge to release it
    5. 1 - Tri-color cartridge 2 - Black cartridge
    6. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe any ink or debris from the copper-colored electrical contacts on the cartridge.
      CAUTION: Do not touch the ink nozzles or the electrical contacts with your fingers. This can result in clogs, ink failure, and bad electrical connections. Figure 13: Clean the copper-colored electrical contactsc00617184.gif 1 - Electrical contacts 2 - Ink nozzles Figure 14: Do not touch the copper-colored electrical contacts or the ink nozzles Place the cartridges on a clean sheet of paper, with the nozzles facing up.
    Step five: Clean the electrical contacts inside the product
    1. Dampen a clean, lint-free cloth or swab with distilled water, and then wipe any ink or debris from the electrical contacts inside the carriage
    2. Let the cartridges and carriage sit for 10 minutes to allow them to dry, or use a clean, dry swab to dry the contacts.
    3. Slide each cartridge into its slot at a slight upward angle, and then press firmly until you hear the cartridge click into place.
      • Install the tri-color cartridge in the slot on the left.
      • Install the black cartridge in the slot on the right.
      I hope this helps you!
May 26, 2011 | HP PSC 2410 All-In-One InkJet Printer
Cassette gets entangled, and does not play well
Cassette tape machines will occasional require maintenance after a certain period of usage. First open the cassette door and remove the tape and any broken tape remaining inside. Some models allow you to remove the cassette door allowing you to have better access to clean the unit. Next you will need to clean the capstan with alcohol and a Q-tip. The capstan is the metal post which the rubber wheel (pinch roller) pushes against to drive the tape across the tape head. Basically clean all the shiny metal parts including the tape head. Some of the tape residue may be difficult to clean, I use Tricloroetilene which has been regulated by the government, but you may try a product called Goof Off to clean the difficult parts, but it could eat the plastic and rubber parts so be careful. Next use a rubber cleaner on the pinch roller so you do not dry the rubber out, or it will become useless. The other problem is the cassette may be driven by a motor and belts. The belts may need to be replaced and the pulleys cleaned. For this you will need to disassemble the unit to access the belts but the cleaning of the pinch roller and capstan may fix your problem, if not you need to open it up to replace the main belt.
Jun 23, 2010 | Philips 3-Disc Changer FW320C Cassette/CD...
The printer is saying there is a paper jam but there is no paper stuck any way in the machine.The resume button does not resolve the problem.
The paper jam may not be very visible and obvious. It may be somewhere after the rollers. Some paper may be stuck in some place in the paper path. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside. OR the teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Nov 17, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Hi! I have an HP officejet 5510 all-in-one product. Suddenly there is no paper feed anymore. I hear the motor (or something like that) to try to pick up the paper, but the paper doesn't move, and the...
Hi
Thanks for using FixYa. To clear the error with the rear access door or duplexer still removed, clean the paper rollers.
  1. Lightly moisten a clean, lint-free cloth with distilled or bottled water, and then gently wipe the large paper rollers inside the product. Manually rotate the rollers to clean all the way around the rollers, and then allow the rollers to dry.
  2. Check to make sure that all of the paper rollers on the rear access door or duplexer are present and not missing.
  3. Clean the rollers on the rear access door or duplexer using the same method used to clean the large rollers inside the product, and then allow the rollers to dry.
  1. Make sure that all of the rollers move smoothly.
  2. If a duplexer is installed, open it to check for any obstructions.
  • 1 - Latch on top of the duplexer
  • 2 - Duplexer cover
  1. Close the rear access door and make sure that it is securely fastened. If using a duplexer, make sure it is closed correctly and reinstall it on the back of the product.
If still the issue is not resolved please refer to this link.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | HP DesignJet 250c InkJet Printer
I have cannon image runner 4570 that I cleaned
The transfer roller is cleaning use to a vacuum cleaner.The black lines is caused to dirty charge corona or charge roller.Clean the charge unit.
Aug 19, 2009 | Canon Office Equipment & Supplies
Fax machine says Rec. Paper Jam
Check the paper, is it loaded correctly? Have you fanned the paper to break the production bond? Is the paper a good quality? Remove all of the paper and check inside for any foreign objects.(paper clips, staples) Reinstall paper. Mark the top sheet of paper with an x, press the copy button, does it even try to pull in the paper?
If yes, the pick up rollers are likely dirty, and need to be cleaned, remove the paper and clean the rollers with some isopropal alcohol, and a soft cloth. (available at a drug store) Retry
If it doesn't try at all, then turn machine off and unplug it for a few minutes,re connect, power up. Any change? if not machine has a feed problem that may require a Tech to look at.
Hope this is of some help.
Ed
Apr 20, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Paper Jams
clean with a soft cloth and alcool the Paper Sensors, specialy the paper sensor (one under the drum), and also the clean the stripper pad, Pickup roller, Scraper roller, Gide roller, Timing roller in the firts paper feed drive mechanism
If you need the manual instructions post a mail at: Salasidis@sch.gr
Feb 25, 2009 | Riso RZ220 Duplicator
Cleaning carbon off inside rollers of HP 1020
Pry up at the ends. Don't get the roller wet.
Jan 30, 2009 | HP LaserJet 1020 Printer
Got a new part. don't know how to install it
I assume you either have recieved the separation pad or the paperpick roller. Here are instructions on how to replace both.
  1. Use the power switch to turn the product off and then unplug the power cord. Figure 1: Unplugging the power cord c00062340.gif
  2. Open the print-cartridge door, and remove the print cartridge. CAUTION: To prevent damage, do not expose the print cartridge to light. Cover the print cartridge or place it in a black plastic bag, if necessary. Also, do not touch the black-sponge transfer roller inside the product. Touching the transfer roller can damage the product.
  3. Locate the pickup roller. Figure 2: Removing the print cartridge, and locating roller c00062341.gif
  4. Gently release the small, white tabs on each side of the pickup roller by pushing them away from the roller, and then rotate the pickup roller toward the front. CAUTION: Use gentle pressure to release the small white tabs to avoid breaking them. Figure 3: Releasing the tabs c00062342.gif
  5. Gently pull the pickup roller up and out. Figure 4: Removing pickup roller c00062343.gif
  6. Perform one of the two following options:
    • Cleaning the pickup roller:
      1. Dampen a lint-free cloth with isopropyl alcohol, and scrub the roller.
      2. Using a dry lint free cloth, wipe the pickup roller to remove loosened dirt. Figure 5: Wiping the pickup roller c00062344.gif
    • Removing the new pickup roller from its packaging.
  7. Position the cleaned or replacement pickup roller in the slots on the pickup roller frame. NOTE: Circular and rectangular pegs on each side prevent incorrectly positioning the pickup roller. Figure 6: Positioning pickup roller c00062345.gif
  8. Rotate the top of the pickup roller into position until the white tabs on each side of the roller snap into place. NOTE: Touching the transfer roller can damage the product. Figure 7: Reinstalling the pickup roller c00062346.gif
  9. Reinstall the print cartridge and close the print-cartridge door.
  10. Plug the product in, and then use the power switch to turn on the product. Figure 8: Plugging the power cord in c00062347.gif
  11. Use the power switch to turn the product off and unplug the power cord. Figure 1: Turning off power and remove power cord c00062407.gif
  12. At the back of the product, unscrew the two screws that fasten the separation pad and frame to the product. Figure 2: Unscrewing the separation pad c00062408.gif
  13. Remove the separation pad and frame. Figure 3: Removing the separation pad c00062409.gif
  14. Perform one of the following two options:
    • To clean the separation pad: Dampen a lint-free cloth with isopropyl alcohol, and scrub the separation pad.
    • To replace the separation pad: Remove the new separation pad from its packaging
  15. Insert either the cleaned or replacement separation pad and frame and fasten it to the product with the two screws. Figure 4: Fastening the separation pad c00062410.gif
  16. Plug the product in, and then use the power switch to turn on the product. Figure 5: Turning the product on c00062411.gif
Nov 17, 2008 | HP LaserJet 3015 All-In-One Printer
Canon imageRUNNER C3200 Copier Logo
32 people viewed this question
old marine
old marine
