Question about Maxtor OneTouch II external hard drive 300GB 7,200 RPM - FireWire & USB (E04W300)
Computer does not recognize Maxtor OneTouch
My computer does not recognize my Maxtor OneTouch. This just happened about a week ago. Until then I was able to back up my programs....I do need help immediately as I am trying to back up my data on Quicken....
Also, it says that it is locked, how do I unlock it???????
Thanks,
Carol Woods My Maxtor One Touch 2 USB & IEEE 300 GB drive is not recognized with an unit letter and is marked with a yellow question mark in device manager. Seagate support has a database filled with similar problems but no complete solution. The Windows XP pro SP3 machine does opem the new hardware install guide every time the external drive is powered but fails to install the XP drivers for USB. Problems started when shutting down the USB connection and truying the Firewitre connection one at the time. The drive is not recognized as a Firewire unit at all !
The suggestion to try the drive on another PC did not work as I used a VISTA home PC Pavillon d9350ea and the VISTA problems are also well described from SEAGATE with no support for VISTA for the Maxtor One Touch 2 300 GB drive.
I would very much like a full solution to save data from drive !
HELP us !
  • Anonymous Aug 09, 2008
    worldvet: more help needed
    The suggested steps were done. Still the drive is not assigned a unite letter. Still the drive is marked as unknown device. The MAxtor One Touch 2 software was removed, system restarted, the found new hardware dialog entered and directed to the Maxtor drivers CD.
    Results were the device could not be installed.
    A new test was done with the 1394-cablage but drive was not found as IEEE unit.
    Please guide me how to install standard XP USP drivers without using MAxtor software.
    The 300 GB drive have worked both as USB and IEEE from 2005 - 2008.
    How can I dedicate a unit letter to the unknown device ?
    Thank you / ah2foto
  • Anonymous Oct 05, 2008
    The suggested fixes with reinstalling software and cables failed. I choosed the hard ware way and
    installed it in a new external power-supplied-cabinet (chassi) by Deltaco. It was easy to remove and install the drive in the cabinet. All data is recovered and the drive is recognized as an USB external drive. End of story.
  • 6,487 Answers
You can try to create a short cut for this concern and lets see if you will be able to check that drive, Just right click anywhere on your desktop screen and select New>Shortcut then if if you already has a existing drive C, D and E try to put there F: then check if you will be able to access that external drive using that shortcut..
Hope that helps........
Posted on Aug 09, 2008
  • 13,434 Answers
Unkown device, in usb devices which should install automatically generally tell of a faulty device.
heres something you can try
http://www.fixya.com/support/r569923-usb_devices_not_recognised_or_not
  • Ekse Aug 09, 2008
    have you tried the device in another computer?
  • Ekse Aug 09, 2008
    if you get the same issue in another (try Xp this time, not vista) computer, that tells me that there is a hardware problem in the controller between usb and the harddrive inside the case.
    your data is most likely all still safe in the harddrive.
    Guru:
  • 859 Answers
Sounds like you need to remove the cable, uninstall the software, Restart, and then shut down. Now, from a cold power off power on. I know this seems tedious, but it has to do with the Last Known Good Recovery File and what is in Device Manger.
Now reinstall the software and if the software should call for you to "now" connect the USB cable, do so only when prompted or when the installer is done. Re: the latter, attach the cable. Windows ill say it discovered new hardware, point windows to your CD drive where the installer disk is located and allow Windows to locate the software.
Shut down and restart and your drive should be recognized now when you have a desktop. If not, post this back using the comment box below.
When replying to mine or anyone else's reply please address us in your reply, such as Worldvet: that doesn't make sense, please explain. And so on and so forth. This allow US to track what you've tried and from whom you were provided the solution.
Thank you for you indulgence on this. And, please be aware that, we all here want to see you fixed up and on your way. We all have a pretty good track record. However, there are times when a repair from a warranty service center is the only solution. However, I'm certain we all can get you taken care of and thanks for using Fix Ya.
Regards,
Worldvet
Posted on Aug 06, 2008
SOURCE:
I have a Maxtor OneTouch 4 Plus 500GB external harddrive...I originally used it on a really old dell desktop computer but since then recieved an HP pavilion laptop...the laptop has windows vista. At one...
1.) Right click My Computer
2.) Click on Manage
3.) Click on Disk Management at the left side panel of Computer Management
4.) Right Click on the USB device in the Disk Management panel
5.) Click on Change Drive Letter
6.) Assign an Alphabet from E-Z to the USB device
7.) Click Ok
Go to My Computer and find the drive letter that you have assigned.
Hope it helps.
Jun 02, 2017 | Maxtor OneTouch 4 Plus 500GB External USB...
Hay i am having Maxtor OneTouch 4 Mini (160GB).it does not detected by any computer except where its software is installed.plz ans immed
I've had this problem before (something similar) you'll need additional software from Maxtor.com so you're PC will recognize the new drive.
Jul 18, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
Jan 08, 2009 | Maxtor OneTouch III 500 GB Hard Drive
I have the same problem, but havent found ay way around it.......i am also getteing pritty desperate here................the old one had this problem...cant fint it in device mannager, dos or anywhere else....no matter which computer i try, xp, vista no deifference...
Aug 04, 2008 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch 4 500GB External USB 2.0 and cannot access it. My computer does show only icon with now information
It is a bit boring and I do not know why it should be but for some reason your computer and new hard drive do not strike it off initially, just like other new-comer situations. Just keep on trying.
With your computer on, plug in external drive and switch on, it should then give a signal to your computer that a new device has been added. This provided that you are running ';Windows millennium, xp later DOS.
It seems to me that The Maxtor Being a "removable device" needs to be unplugged and plugged in again whenever you restart your computer, Perhaps this is what is happening, However as in my case I continued to do this until until the my computer got to rely on the new hard drive so much it could not run without it.
Good luck
Goffa
Jul 24, 2008 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
The problem is just with EXTERNAL.
Hdd is fine...Just change the external or buy new
Nov 18, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Open Questions:
-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A
Oct 16, 2019 | Computers & Internet
-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}
See all Maxtor OneTouch II external hard drive 300GB 7,200 Questions
Maxtor OneTouch II external hard drive 300GB 7,200 RPM - FireWire & USB (E04W300) Logo
517 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
