My computer won't recognize my new 80GB Seagate IDE hard drive so I need instructions of how to install it properly or some instructions after the install
  • 749 Answers
Explaining without figures is hard... click on this link to help you more. CLICK ME
Posted on Aug 06, 2008
  • 144 Answers
Go to the bios setup during boot & check whether this drive is shown there. If not, Check whether you have connected the drive rightly. i.e. the connections for IDE cable & power cable are securely connected.
Also, check whether you have setup the master/slave/cable select jumpers rightly..
Set the jumpers on your hard drive for cable select. If you have another drive also connected via same cable, then set the jumpers on that drive for cable select mode.
Alternatively, set one of the hard drives as master & other one as slave.
Also make sure that you have connected the cable in the right direction. Long leg of cable towards the motherboard side & short leg towards the hard drives side.
Hope this helps you friend..
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
Hi, I tried to install a new Seagate 500GB HD on my windows XP system, I also used a bridge card to adapt the drive, as my system is IDE, the new Seagate is SATA, no jumpers on this drive. Problem is once...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Feb 25, 2011 | Seagate 500GB SATA HD 720016MBSATA3G 500...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Seagate SATA 80GB Master Drive and Seagate IDE 80GB Salve Drive
Dear,
You have to make IDE drive as slave. For this put the jumper to slave in IDE drive. Possibility of CMOS battery is rare, but you can confirm it by checking your system time in BIOS. If system time is ok then there is no problem in CMOS battery and you need not to replace it.
Thanks,
Rakesh Kumar
Jul 23, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computer did not bootup after adding 2nd harddrive
Did you connect the drive to cable spot closest to the motherboard on the primary IDE channel? is it formatted? Did you try the drive on the Second IDE channel? Can your system support a 160 GIG drive?(if not try partitioning the drive.). Is the power and data cable connected properly?(the red line on the data cable should be closest to the power plug on the drive.)
Apr 11, 2009 | Sony VAIO PCV-RS530G (PCVRS530GFS) PC...
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Hard drive settings
d5e7986.gif Jumper settings for Seagate ATA/IDE Internal drives <20gb & greater
For older/smaller drives visit www.seagate.com
Jul 13, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
A larger capacity replacement drive for my st380020a 80gb drive
The IDE version of a 160gb is a:
Seagate Momentus 160GB IDE Laptop Hard Drive
Part Number: 9S1034-506
Model Number: ST9160821A
5400RPM
The SATA version is a:
Seagate Momentus 7200.2 ST9160823AS 2.5-inch 160 GB hard drive
Jan 31, 2008 | Computers & Internet
Shrinked
This is the maxtor 4 installation utility: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=MaxBlast_4&vgnextoid=7add8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: MaxBlast 4 is a one-step, ATA/IDE hard drive installation utility. MaxBlast 4 makes hard drive installations and upgrades hassle-free for novices and professionals alike by automatically identifying, partitioning, and formatting any Maxtor ATA or SATA hard drive, making it data-ready in minutes. MaxBlast 4 replaces all previous versions of MaxBlast and MaxBlast Plus. Powermax 4.23: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=PowerMax_4.23&vgnextoid=a37d8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: The PowerMax utility is designed to perform diagnostic read/write verifications on Maxtor and Quantum hard drives. These tests will determine hard drive integrity. The PowerMax utility is effective on all ATA (IDE) hard drives with a capacity greater than or equal to 500 MB. Maxtor recommends the use of this utility for troubleshooting potential hard drive problems. These problems include, but are not limited to the following: * Potential hard drive surface problems (e.g., bad clusters, bad sectors, partitioning/formatting problems, etc.). * Drive recognition problems (e.g. hard drive that is not recognized by the operating system). * Software removal.
Mar 20, 2007 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
