Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
When i take a picture the top half is good but the bottom half is black
  • 747 Answers
Are you using the flash? if so then the shutter speed is not synchronized with the flash if no flash is being used then the shutter may need replacement.
Posted on Apr 06, 2011
Only have part of picture on phillips 50tv
Are you missing the top portion of the picture or the bottom portion of the picture? looking inside the TV will reveal two modules to the furthest left of the inside. These are the upper and lower Y buffer modules. Replace the top one if missing the top half of the picture or the bottom one if missing that segment. Usually you can find good used parts on Ebay. Or Shopjimmy.com.
PHILIPS 50PF9631D 37 BUFFER BOARDS LJ41 03883A LJ41 03882A
Apr 05, 2015 | Philips Televison & Video
Bottom half of screen is black
The display strip is not properly seated in the connector base. That is a hardware problem so dont think of a software error.
Oct 07, 2014 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
RCA serial 137651043, model P52939, 55 inch tv.
Half black? top/bottom or left right?
The set is rather old--a old trick to use is to connect a fan to the rear of set with the back off--it may extend the life of the set and give you some more use out of it.
I have seen a lot of these sets and never one with the problem you describe. If only a picture top or bottom is missing it may be vertical or if you are seeing what looks like a full picture with top or bottom black it is a Blanking problem--may not be easy to find...........
Apr 25, 2012 | RCA P55000 55" Rear Projection Television
Bottom half of screen black-out
I would replace the lower Y buffer. Part number 996500032640. Goodluck.
Jul 05, 2010 | Philips 42PF7220A 42 in. Plasma Television
I have a panasonic TH-50px75u i can only get half a picture on
DONT BUY THE CHEAPER MODELS. GOTTA SPEND SOME DOUGH FOR A GOOD ONE. DONT BE CHEAP
Apr 27, 2009 | LG 42PC3D 42 in. Plasma Television
Toshiba 35A44
check the verticle stage
electrolitic capacitors
and the verticle IC
Sep 04, 2008 | Toshiba 35A44 35" TV
Tv play but no picture
I have a 51" magnavox plasma. after about one half hour the bottom half of the picture goes black, and u can still see the top half of the picture. what can that be
Aug 11, 2008 | Televison & Video
Half picture shows up and top portion is black
The camera firmware should be reloaded, if this fails then the camera is likely beyond end user servicing and should be repaired by a professional.
The reason your only seeing bottom half is as the reflex mirror is opening upwards to expose the sensor ( traditional cameras opened the mirror then a shutter to expose film ) your cameras sensor is only registering or transferring the bottom half of the image because it is the image is registered bottom first to the top until the shutter closes and the mirror returns to resting position.
Your problem could be the result of firmware or a more serious issue.
Aug 10, 2008 | Nikon D40x Digital Camera
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
111 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
