Question about Zebra Printhead for LP2824
PUT PRESSER ON PRINTER HEAD TOO GET A CLEAR HANG TAG, CAN IT BE ADJUSTED ?? LP2824
  • 11,800 Answers
No, it's a self-centering fit, it cannot be altered.
Posted on Apr 06, 2011
Can the feed dogs be adjusted up or down on a husqvarna viking quilter
They are adjustable but should be done by a sewing machine technician. Special tools are needed to get the setting right.
If the feed dogs are not pulling the fabric through the machine, check the presser foot pressure adjustment. It tightens the pressure on a spring on the presser foot bar causing the presser foot to apply more or less pressure to the fabric. The pressure adjustment can be located several places but usually around the head of the machine--to the left of the needle or at the very top of the head. Some older machines simply have a screw that is located under the top lid.
Jan 04, 2017 | Husqvarna Sewing Machines
My Zibra LP2824 Plus flashing red and green lights, how can i fix this problem as i'm in a remote place and don't have technical service for it?
Go to this site it will explain the lights and should tell you enough to fix it
https://km.zebra.com/kb/index?page=content&id=SO8026&actp=RSS
Jul 13, 2016 | Zebra LP2824 Plus Barcode Printer - USB
Error 1 keeps coming up on display. Batteries are new, jam cleared from cutter area. No other jams. Why won't it clear?
I had the same problem. My batteries were fine, there was no tape jam, and I also cleaned the writing head with the DRY tool that comes with the label printer (you find it in the tape box). I opened the casing, checked the motor, etc. but nothing seemed to help. My last recourse was then to GENTLY clean the writing head by taking a lens cloth and putting some alcohol on the cloth. WOW! That worked!! Brief summary: Take a lens cloth or the tool that comes with the label printer and put some alcohol on it. Then GENTLY clean the writing head. I hope it works in your case, too!
Jan 20, 2012 | Dymo LetraTag QX50 Thermal Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Bar code is not dark enough, can it be cleaned
Turn up the darkness setting. Here is a video on how to clean a printer, it isn't the same model but the procedure on the printhead is the same. At about 50 seconds into the video it shows the printhead which is basically the same on the LP2824. http://www.racoindustries.com/thermal-label-printer-cleaning.htm
Ben
Jun 25, 2009 | Zebra TLP 2824 Printer
Part of the tag does NOT print out.
DID YOU CLEAN THE PRINT HEAD AND BRY IT GOOD, CHECK THE SOFTWARE.
MAKE SURE THE MATTERAIL IS THE SAME FOR EACH TAG, DIFFERANT TYPE OF MATERAIL WILL GIVE DIFFERENT TYPE OF PRINT AND THE FINAL PRODUCE WILL BE TOTALY DIFFERENT.
SEE IF THE PRINT HEADS HAVE THE SAME CLEAR-INES, SEE IF THE HEADS HAVE APART THAT CAN MAKE THE PRINT A BETTER PICTURE OR BETTER QUILITY OF PRINT.
SEE IT THE PRINT HEAD HAS ANY TYPE OF HEAD ADJUSTMENT, REQUEST A SERVICE MANUAL FOR THIS TYPE OF ADJUSTMENT AND YOU WILL NEED SOME FILLER GIUDGES TO MAKE THAT SDJUSTMENT THE SAME ONES YOU USED TO FIX THE OLD CAR WITH THE FLAT SILER ONES
ROD GANDY
Feb 17, 2009 | Zebra Printer 140-751-00000
Slow printing to LP2824
This appears to be normal operation.
Aug 14, 2007 | Zebra Eltron LP 2824 Thermal Printer
LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra Printhead for LP2824 Logo
44 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
