Question about KitchenAid KSSC48QMS Side by Side Refrigerator
Two-beep alarm is activated. Freezer temp/refrige temp/filter percent remaining LEDs all flashing. No other lights are on (over temp reset, call service). Pressing over temp reset results in a beep, followed by no change in alarm or flashing LEDs. Cannot enter diagnostic mode. Condenser fan not running. Unit seems to be holding cold temp OK. I suspect condenser fan is inop, but don't know how to confirm I don't have a different issue. Also, if fan replacement is necessary, where can I get a replacement? Thanks, Tom Massicotte
  • 2 more comments
  • t_massicotte Apr 06, 2011
    I have found a local source for the fan motor. I will replace today (hopefully) and get back to you as to success.
    Thanks, Tom
    Just swapped out the condenser fan, and there is no change in the symptoms. Condenser is running, but the fan is not. I didn't mention it earlier, but yes, everything is clean and there is nothing obstructing the fan blade.
    What now?
    Just to add to my last post, I did replace the condenser fan motor, blade, and bracket.
    OK, per the service manual I downloaded from FixYa, the condenser fan is 120 VAC. So, how do I test the fan with a 9-volt battery? Which pins do I use on the fan connector? And, if I try to check the supplied voltage at the fan, do I do it with the fan disconnected electrically? I'll assume I would use the same pins used above to check the fan with the 9-volt battery. Is this correct?
    Thanks, Tom
  • 5,370 Answers
Its the fan issue.the fan is not working so the beep is indicating to replace the fan.But Check if there is any blockage to the fan.If some thing is obstructing the fan from spinning then cleaning the fan dirt should help.But if you are able to spin the fan manually, and its not turning when unit is on, then its faulty fan it has to be replaced. the condenser fan blade runs with the condenser motor.So you will get the whole fan assembly, that includes the fan blade and motor.That has to be replaced.To see how this looks.Please see the fig below:---- Two-beep alarm is activated. Freezer - helpmech_107.jpg
To order this part.Please click the link below:---- http://www.repairclinic.com/PartDetail/Condenser-Fan-Motor/1378525 -------------- this part comes with complete instruction for installation.----- if you require disassembly instructions for the upper unit to remove the condenser fan motor.please click on the link below:---- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSSC48QMS00/0593/0165000/W0306036/00013?blt=06&prst=&shdMod= ---------- part number 16 in the link is condenser.part number 23 in the link is for condenser motor. ---------- If you need complete refrigerator disassembly.Please click on the link below:--- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSSC48QMS00/0593/0165000?searchedModel=KSSC48QMS&blt=06 -------------- This should help.Keep updated.Thanks.Helpmech.
Posted on Apr 06, 2011
  • 1 more comment
  • raj somaiya Apr 06, 2011
    Yes keep updated.Thanks.Helpmech.
    The condenser motor gets power from main board to start the fan.If the motor is replaced but still the fan not turning on, this means the main board is faulty and its causing the issue.Check the fan motor separately by connecting it to 9V battery.Or check the voltage at the fan motor.If it shows 12volts, then its ok and board is the issue.If it shows no voltage, there there is short in motor to main board connection or connection is loose.----------- This should help.Thanks.Helpmech.
    Yes correct, you have to use the same pins used above to check the fan with the 9-volt battery.Yes correct, if you directly check motor connected to fan blades, with main power to the unit, its 120vac.If that case, you can directly check the motor by meter.The reading should be there.If its not showing 120 vac, then board is not giving power to motor.If its giving more then 120 vac, then there is short in wiring.But if its not showing 120 vac, then main control board has to be replaced.-------This should help.Thanks.Helpmech.
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 03, 2015 | Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Apr 25, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Hi friend has a fisher and paykel refridgeator and its sounding an alarm of one beep and then 3 or 4 long beep followed by a short beeps then then a single beep its a top freezer model and the refrigeator...
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 11, 2010 | Fisher and Paykel Active Smart E522B...
KitchenAid KSSC48QMS Side by Side Refrigerator Logo
191 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
