Question about Behringer Co600 Chorus Orchestra Effects Pedal New
Chorus Orchestra Co600 is not working...I can no longer hear the chorus effects. How can fix this kind of issue?
2 Suggested Answers
  • 5603 Answers
SOURCE: basically i cannot seem to
Norrmally you run the guitar into the pedal and then into the amp. IF you want it behind the built in effects, The look on page 6 of your users manual showing the special cable you will need to do the "insert" of your effects pedal.
If you don't have a manual, download it here:
http://www.crateamps.com/pdf/manuals/FW120H_OM.pdf
Posted on Jan 11, 2011
Which is the best chorus pedal for a guitar?
According to me and many professional guitarists, the best chorus pedal is "MXR M234 Analog Chorus Guitar Effects Pedal"
It is durable and easy to use.
Some of its best points are:
? Volume is consistent
? Affordable price range
? Versatile tone and effect
You can check many other effects pedal at this link:
Best Chorus Pedal Top 5 Best Chorus Pedals for Your Guitar 2017
Feb 22, 2017 | The Music
How do you use a four way footswitch
Need more info. What kind of foot switch and what are you hooking it up to. For guitar they are used for switching distortion to clean on 1 switch, one for reverb, one for chorus, and possibly 1 for bypass. All depending on the amp you use, and what effect the amp has built in it. Some amps only have clean and destortion which make the other channels on the footswitch useless. Hope this helps.
Dec 31, 2014 | Music
User manual for DOD DFX9 DIGITAL DELAY GUITAR PEDAL
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
Mar 09, 2013 | Applause MAE148 AcoEle Mandolin Natural...
Chorus emits a pulsating noise
Sounds to me like low-end gear. You honestly get what you pay for. If it happens to be high-end then you have either bad cables or just a bad effects processor. If you have on-board effects built into the amp, then get better equipment.
Hope this helps.
Aug 31, 2012 | Ibanez IBZ10A 10 WATT ACOUSTIC AMPLIFIER...
Chorus on- no problem- noise free. Chorus off- big problem- massive hum. This item is supposedly "new" (stupid me, I bought from Ebay...)
It sounds like the bypass contacts on the pedal are not working... this may be right in the pedal switch itself. With unit in off position, use an ohmmeter to check continuity between in and out cable tips.
Sep 07, 2011 | Electro-Harmonix Electro Harmonix Neo...
How To Use The effect Loop?
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
May 12, 2011 | Peavey 6505+ 112 Combo Amp Combo
MY MXR STEREO CHORUS LED LIGHT START TO FADE AFTER CONNECT WITH DC BRICK! DOES THIS MEAN MY PEDAL WILL HAVING ANY DEFECT?
I don't know what you mean by "DC Brick"...
The MXR Stereo Chorus unit requires a special 18 Volt power adapter. The common 9 volt pedal power adapters will NOT work with this device. If you have batteries in the unit, when you plug in an incorrect adapter, the unit disconnects from the batteries and the caps discharge so the light will fade.
You will need to use: ECB-004 18-volt AC Adapter Best to use the manufacture's exact device for this one.
Jan 12, 2011 | MXR Stereo Chorus Pedal Guitar
Peavey classic chorus 212 buzzes, sguelches, squeals...
There MAY be a circuit trace on a board that is cracked OR a poor soldered connection. It is vibration sensitive as you have found. Changing a switch vibrates the unit.
Depending on what you have connected, this could even ba a bad input jack.
The unit needs to be serviced. You could open it and see if there is something obvious.
Jan 13, 2010 | Peavey Jsx Mini Colossal Guitar Amplifier
How to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
Nov 24, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Behringer Co600 Chorus Orchestra Effects Pedal New Logo
16 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
