Power up, power on light illuminates, drive light illuminates (yellow light), nothing to monitor, monitor remains black. Power supply gone or is their a reset or internal fuse for computer. Thyanks
    Scholar:
  • 85 Answers
Usually, this is a problem with the power supply. Try changing the current power supply with a new or working one. Also, check if all the cables are properly inserted. If the problem persists, you may have a defective motherboard.
Posted on Apr 06, 2011
Testimonial: "Thanks for the info, kind of figured the problem but it is great to have the opinion of a pro. Thanks again."
My I plugged in monitor the yellow light on just less than 1 second. then it off and monitor do nothing. no display, just black screen as in unplugged state. This my favorite monitor. I checked horizontal...
Hi, please consider that you have an issue with power supply of your CRT. Before checking any possible active components on it, first check the power switch. Then proceed to check power capacitor in the power supply.
Jan 19, 2014 | Philips Professional Brilliance 109P...
Black display
You say black display. Not sure what you mean. Either the monitor is working or it is not. If you see nothing on the monitor and the power light is yellow, then it is not getting a signal.
If the power light is green and you see nothing, look really closely. You might even shine a flashlight at the monitor to see if there is actually a dim display. If so, the backlight has gone out and needs to be replaced.
I'm assuming that you have tried to brighten the display with the monitor controls.
Jan 09, 2012 | ViewSonic VA720 17" LCD Flat Panel Monitor
Black screen
At this point I believe there are failed caps in your monitor.
http://www.badcaps.net/forum/showthread.php?p=73310
This is very common in all LCD monitors. Did the tech just push the power switch off and on?
From my experience at fixing broken monitors of all brands, I think it is the power supply problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
You can get second help from repair shop also.
Apr 20, 2010 | Gateway FPD2275W LCD Monitor
Emachine w3507 blue light only comes on fan runs nonstop, no signal or monitor, pressing the f8 did nothing
If you get nothing but a blue light and no video at all it sounds like you have a bad power supply. They are easy enough to check and replace but not for a first timer. If you know someone who knows more; get a volt meter and put it on the DC scale. Unplug a power plug to a drive or find one that is not used. Measure the Yellow to black and then the red to black wires. You should get 12 & 5 volts respectively.
Apr 18, 2010 | eMachines W3507 PC Desktop
SyncMaster 940N - screen has gone dark when turned on and computer booted up. If I get close to the screen I can just about see something on the screen. I have brought up the service menu and all the...
Your problem is usually caused by a bad power supply. You should be able to do the repair yourself, if just requires replacing 6 capacitors on the power supply board. Here is a link to a repair guide that shows how to disassemble the monitor and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the a picture of the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Apr 16, 2010 | Samsung SyncMaster 940N Flat panel Monitor
Compaq Presario SR1030NX fails to start
Sounds like the power supply or motherboard is biting the dust. U may consider power off, open case and clean out the dirt, check U'r connections and if the power supply smells, replace it.
Else replace the pc. When the power supply dies, it usually stresses the motherboard out and it dies later, sooner.
Jun 02, 2008 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Acer al1714
The problem may not be the monitor. Acer AL1714 is known for its weak power supply unit. Unplug power supply from monitor. If the green light on monitor comes on but goes out quickly, the power supply is the culprit!
Dec 28, 2007 | Acer AL1714 17" LCD Monitor
NO PICTURE
Bad power supply. The light is green when it is not plugged into the monitor because there is no load on the power supply. When you plug it in the monitor tries to draw current, nothing the PSU can handle now, so the light blinks. The PSU can not provide the amps that the monitor needs.
Get a new power supply, you can find them on ebay. Just make sure the voltage and amps match. It is ok to buy a power supply with a higher amp rating, the monitor will only take what it needs. Also make sure the power plug that plugs into your monitor matches.
Nov 16, 2007 | Neovo SX-19A (Black) 19" LCD Monitor
Computers & Internet Logo
217 people viewed this question
David Payne
David Payne
