Question about Sharp EL-1197P Calculator
Need to set date & time on sharp EL-1197P - Sharp EL-1197P Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
See the instructions on the first page of this manual.
Posted on Apr 07, 2013
drknow
  • 44 Answers
SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Dec 19, 2007
SOURCE: Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Posted on Mar 24, 2008
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Posted on Dec 04, 2008
  • 207 Answers
SOURCE: I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 27, 2009
  • 175 Answers
SOURCE: how to set date and time on sharp el-1801pIII
User guide is here ...
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/EL-1801PIII-_E
Instructions are halfway down column 1.
Basically, you use the reset button on the back, then enter the relevant fields, delimiting as with a period <.>
I think their illustration explains it better than I can in words!
Posted on Feb 28, 2010
How do I set the date and time?
Follow the instructions on the first page of this manual.
Nov 12, 2010 | Sharp EL-1197P Calculator
Setting the date? and Time?
Jul 05, 2010 | Sharp EL-1197P Calculator
How to set the date on a Sharp EL-11979
Apr 12, 2010 | Sharp EL-1197P Calculator
How to change date and time on a sharp EL - 1197P calculator
Found Instructions for EL-1197PIII Calculator, think its the same thing
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position. Date: · Enter in the order of month, day and year, then press to complete the entry. · Use to separate month, day, and year. · When is pressed, the number entered is evaluated and displayed as “date” if the value is within the following range; “Error” is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: · Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) · If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”. · Use to separate hour and minute values. · When is pressed, the number entered is evaluated and displayed as “time” if the value is within the following range; “Error” is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Apr 06, 2010 | Sharp EL-1197P Calculator
HOW DO I CHANGE THE DATE AND TIME?
Only the EL-1197PIII has time and date settings, so I assume you own this model. A link to the manual is here: http://www.sharpusa.com/~/media/96B576A9DADF49A0B1321B57CAB1741D.ashx
You can find the time and date set up process on the first page, 3rd column, 2nd paragraph, under the headline GRAND TOTAL/RATE SETTING MODE SELECTOR.
Feb 11, 2010 | Sharp EL-1197P Calculator
HOW DO I SET THE TIME ANDDATE ON THIS
Jan 08, 2010 | Sharp EL-1197P Calculator
Need manual for sharp calculator model el-1197p
You can download the required manual from:
http://www.retrevo.com/support/Sharp-EL-1197P-Calculators-manual/id/358bh050/t/2/
On the page which opens, click on GET MANUAL button and follow the instructions on next page to download the manual.
Hope this solves your problem. Thanks.
Sep 19, 2009 | Sharp EL-1197P Calculator
How do I set the date and time on the EL 1197P III
http://www.sharpusa.com/~/media/3F4ED1815067459995912CEE6A6A6DCB.ashx?cal_man_el1197P.pdf
Mar 13, 2009 | Sharp EL-1197P Calculator
Problems with my calculator sharp el-1197p
If the top button, third from the left is set to K it acts like a calculator. If you push it over to A it acts like an adding machine.
For an adding machine: type the number first then hit the function (i.e. +, -, x,...)
Feb 12, 2008 | Sharp EL-1197P Calculator
Clock & Date
You can download the manual from the link below: http://www.sharpusa.com/files/cal_man_EL1197PIII.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Sharp EL-1197P Calculator
Sharp EL-1197P Calculator Logo
81 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
