Question about Samsung ML-2510 Laser Printer
Printer is not feeding paper into printer reliably
  • 24 Answers
Need to check the printer maximum the pick up roller and friction pad(paper seperation pad) have to be replaced cont:9848878646 hyd
Posted on Apr 06, 2011
What is a PF kit
This is a "Paper Feed" kit and comprises several small pieces including rollers, springs and friction separator pad. Some models have several of these and will be named "PF1 kit", "PF2 kit" etc normally one for the manual feed tray and one for the paper drawer.
If you look at the front of the paper drawer, you will see a spring loaded friction pad in the centre used to hold back all but one sheet of paper. Directly above this in the printer chassis will be a loose rubber roller assembly which grabs the sheet of paper. together, this collection of parts is called a "PF kit".
The printer memory counts the number of pages fed and will count down an estimated useful life of these parts but this is at best a "guess". When they will no longer reliably feed fresh new paper without jamming, they probably need replacing.
May 30, 2014 | Brother MFC-8460N Laser Printer
Feeding envelopes
Envelopes have always been a problem with the Riso feed mechanisms. Most envelopes have an imperceptible coating on them to allow them to stand up to outdoor conditions better. It makes the paper a little slicker and thus harder for the rubber rollers to feed.
If you want to reliably feed envelopes you need to make sure your rollers are fresh and the angle/pressure settings are exactly right. Good luck!
Apr 09, 2014 | Riso RZ390 Duplicator
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Dell 3100cn printer prints individual colors fine. When printing full color picture the paper wraps around the fuser. Tried new fuser - same problem. Any suggestions?
Good old fuser wrap, what a pain. What type of paper are you printing on. Often with full page coverage printing I find that you need to user a heavier bond color printing paper to achieve any sort of good quality and reliability in feeding.
Mar 18, 2011 | Dell 3100cn Laser Printer
Paper feed is not feeding correctly. It gets jammed.
check for obstruction. lexmark website is not reliable.
Oct 05, 2010 | Lexmark X4650 InkJet Printer
With HP Photosmart D7260 Printer, I get "out of paper" error, paper tray full, feed rollers leave skid marks on paper" I have tried other paper (HP Premium Ink Jet paper, Avery namecard stock, HP Premium...
Perhaps you are loading too much paper into the tray. Please try to work through the steps in this troubleshooter and see if it has any effect. If not, please report back with the results and someone will be happy to assist you.
HP OOPaper
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | HP Photosmart D7260 Printer
Lexmark T630
Repeated, Unexplained Paper Jams With Little or No Damage to the Paper ID:ENUS5286 null.gif null.gif null.gif
IMPORTANT: The printer should rest on a surface that is flat, level, and uniform. This is for safety reasons as well as for paper feed reliability. In the bottom left corner on the front of the printer, as well as on the duplexer and each paper feed option apart from the 2000-sheet feeder, there is a shaft that rotates as the main drive motor in the printer operates. The purpose of this shaft (called the Power Take Off shaft) is to turn the pass-through rollers in the option below. The Power Take Off (PTO) shaft rotates during the printer's POR as well as any time the main drive motor turns, including while paper is feeding from any source and when the toner is agitated in the cartridge.
If the printer is on an uneven or non-level surface, the PTO shaft may not make full contact with the bevel gear on the lower options.
If the printer is on a surface that is not uniform (such as a carpet or foam padding), the PTO shaft on the lowest option may catch or bind, causing the paper feed operation to slow or stop completely.
In either case, repeated and unexplained paper jams (with little or no damage to the paper) may occur. The paper jam is due to the increased amount of time it takes the paper to feed through the path because the PTO shaft is bound or caught on the surface below, or is slipping on the bevel gear.
NOTE: This is not a printer defect or failure although it may result in a broken or stripped PTO shaft.
May 30, 2008 | Lexmark T630 Laser Printer
How to get my Dell Photo 924 to feed paper for printing?
if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Brother MFC 7420 Paper Jam. Paper will feed from tray to Toner/Drum then Jam. Feeds only about 4 inches of the sheet then Jams. I have replaced the toner/drum unit. Any help is appreciated. Thanks.
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Nov 13, 2007 | Brother MFC 7420 All-In-One Laser Printer
Samsung ML-2510 Laser Printer Logo
115 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
