Question about Simplex Kaba Ilco Unican LP1000 Panic/Exit keyless lock
I HAVE TWO LP 1000 DEVICES AND UNLESS I LIFT UP ON HANDLE AFTER IT HAS RETRACTED THEY STAY IN UNLOCKED MODE.
  • 963 Answers
Navigate to this page, which is a grid of the various models of Kaba locks, and select the installation instruction download for your L1000 locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
The download will be a PDF file, which requires Adobe Reader or similar program to view the file. If you don't have it installed, there is a link to Adobe Reader at the top of the grid chart.
When you have the "Manual" downloaded and opened, scroll down to "Troubleshooting" page 40 of 44, where it states
Outside lever when turned always retracts latch without depressing any buttons.
Lock is in zero combination.
Follow the procedure for changing a
combination except omit step 3 (do not enter the existing combination)
This sounds like the solution to the problem you are describing. Good luck!
Posted on Apr 10, 2011
Unlock demo mode
The store is supposed to handle this. See... http://forums.toshiba.com/t5/System-Recovery-and-Recovery/Stuck-in-Demo-Mode/td-p/463457 Unless this device was stolen, you should be able to get the store to resolve the problem.
Jul 27, 2014 | Toshiba 13.3" Chromebook - 2GB Memory -...
Toilet flapper doesn't stay up unless handle is held down until tank empties.
If the flapper won't stay up, you may be lifting it too high - you want to retain a little air inside it when it's lifted. Try adjusting it to a lower lift height.
Jan 12, 2014 | Plumb Pak Plumbing
Want to convert my electric audi 80 roof into a manual one
no need to convert.
the electic roof can be opened manually by:-
unlock the roof using the handle on top of the windscreen and push roof back as far as posible.
lift flaps adjacent to door pillers
you will see a small lever which can be retracted (both sides)
when these levers are retracted the roof will push down fully into its compartment
when erecting the roof ensure that the two levers are fully open to accept the roof retaing lugs
Mar 29, 2013 | 1994 Audi Cabriolet
Wont shout off stays running unless unpluged
Lift handle when done and take out the Kcup. It will stopm.
Feb 14, 2013 | Keurig B50 Coffee Maker
How to unfold a safety first playpen
Most all of the newer playpens called Pack N Plays use a bottom-center
safety device. You must lift up the bottom of the playpen, usually a tab or twist handle. Either lift or twist and lift to be able to drop or raise the sides. YOU CANNOT RAISE OR LOWER THE SIDES UNLESS YOU LIFT THE SAFETY UP. Dont man-handle the sides. Slamming them up or down will break them. Sometimes it helps to lift the side releases before pressing the releases thet are inside the cloth. Basically the floor of the playpen has to be sticking up to allow the sides to raise or lower and lock.
Feb 12, 2012 | Baby Gear
Simplex 1000 lever handle when correct combo put in lock combo lock operates fine except unless you let the lever snap back lock dose not reset in locked position, in other words if you slowly let the...
I don't have a direct answer, but here is the contact info you need for customer service:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
1-800-849-8324 (option 1)
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Tech Support is probably your best bet!
Aug 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How do you do extended recording (6hours)
There will be a camera menu setting where you select SP or LP. LP is longer play.
FYI: Unless you really need this LP mode SP is better for most uses.
May 27, 2011 | RCA CC-439 Camcorder
F 806 rear lift stays up, unless tractor is off....
i would think that the lift control handle is stuck in the lift position, and when the engine is on the fluid will bypass the control handle and thus raising the lift. replacing or repairing the control should solve the problem. good luck
jim
Oct 16, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
JAguar door handles
You have something broke or not working inside the door. You have a huge problem. You will need to remove the door panel with it closed which is going to be hard to do. Once you can get into the inside of the door you will be able to inspect the linkage and figure what is the real problem inside. The door lock assembly will never work correctly till you find out if a clip broke and you can't know that till looking inside
Dec 02, 2017 | 2001 Jaguar XJ
Simplex Kaba Ilco Unican  LP1000 Panic/Exit keyless lock Logo
163 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
