Question about Bushnell Voyager 78-4503 (675 x 20mm) Telescope
Equatorial Mount problem. Gear at latitude adjustment (not the worm gear) is busted. Need a replacement.
  • 3,186 Answers
Only Bushnell will have this part. Contact them here:
http://www.opticsplanet.net/bushnell-warranty.html
Posted on Apr 07, 2011
Not getting oil to blade tried the screw to adjust but still no oil getting throu !!
Your worm gear assembly is probably frozen in with sawdust and dirt. Take off the oil gear assembly. You will need to take off the clutch and the sprocket, the worm gear is directly underneath. Sometimes they are made out of plastic, sometimes of bronze. They use plastic for newer saws. If the gears do not turn easily, when you use your finger to turn them when they are off. then it is probably a good idea to buy a worm gear and then totally clean the assembly. Put in the new gear and it should work. Also check your chain bar check that the hole is clean. They also have a seal around the worm gear under the clutch assembly. It is good that you replace that too.
Nov 23, 2013 | Garden
Repair
There are no adjustments for this machine. Chances are that the plastic gear that is driven by the worm gear has a spot that is worn down and when worm gear hits this spot, it does not drive . Replacing gear is the only remedy. Good luck.
Jul 13, 2013 | Fellowes MS-460Ci Shredder
How to adjust worm gear
worm gear on what as only ever seen a worm over wheel gear set up on a foden 32 ton 4 axle bulker ,they use a special oil as well as the gears are phospor bronze ,Now do you mean a hypoid gear like a modern car differential
Apr 21, 2012 | 1999 Chevrolet C/K 2500
How to replace a worm gear on a Bell & Howell model 2585 16mm film projector.
Replacing the worm gear on a Bell & Howell 16mm film projector is a very long and involved process requiring a complete teardown. It is similar to replacing a blown head gasket in an automobile engine. The worm gear is the heart of the mechanism and takes a lot of time consuming labor just to get to it. In the process you lose a bunch of critical adjustments which require resetting with special Bell & Howell tools/jigs/gauges. Many of these projectors are at least 30 to 40 years old and will also require re-lubrication.
The gear itself costs around $30-ish and takes 3 to 8 hours of labor to replace. Richard Patchett in Michigan and International Cinema Equipment in Miami, Florida does the worm gear replacement.
May 04, 2011 | Video Game Consoles & Games
Is there any adjustment for the gear drive sprocket that meshes with the worm drive? my gear is not engaging any more
If your drive gear is not meshing with the worm gear it is because it is worn out. You'll need to replace it post haste. The part number is 41A2817 and is available at Sears or any good door opener service company.
Dec 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Celestron 114EQ polar setting and Equatorial settings
The ALTITUDE adjustment matches your LATITUDE. I live at 32.5 degrees North latitude. So the scope is first adjusted to 32.5 degrees UP.
Then the Right Ascension is point to Polaris the North star by MOVING the entire scope and mount.
Read my Equatorial mount TIP on my profile page, and read this web site.
http://www.astro-tom.com/tips_and_advice/precision_polar_alignment.htm#Rough%20Polar%20Alignment
May 05, 2010 | Celestron PowerSeeker 114 EQ Telescope
Bernina 730 cam gear replacement and alignment
It does not matter where the position of the camstack is when you put it in, it should not affect any other part of the machine.
Jan 30, 2010 | Bernina Bernette 75
Need a drawing of the worm shaft and spool valve assy.
closest I have is 94 explorer. may be similar.
Item Part Number Description 1 3E501 Steering Gear Sector Shaft Seal 2 3524 Steering Gear Input Worm Gear and Rack 3 3647 Steering Gear Worm Ball 4 3523 Steering Gear Ball Return Guide 5 3A670 Steering Gear Worm Thrust Bearing Adjuster 6 — Locknut (Part of 3577) 7 3571 Steering Gear Worm Thrust Bearing 8 3575 Steering Gear Sector Shaft 9 3524 Steering Gear Input Worm Gear and Rack
May 09, 2009 | 1983 Ford F 250
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
Konus 200 telescope mount
Most of these German Equatorial mounts are sourced from various factories in China and are knockoffs of earlier Japanese models. Konus and other rebranders simply by a lot from one of the factories and do not provide parts or service support. If you have the Konus Newtonian telescope, (200 mm diameter (7.8"), focal 1000 mm.) with heavy-duty equatorial mount, I think that it's made by Jinghua. This is a pretty common mount (Meade sold it for a while and still sells a Jinghua as the LXD-75). Your best bet it to post a wanted ad on Cloudy Nights Classifieds. There are a few of us that keep inventories of spare parts from damaged equipment fro service and repairs. HTH, Geo.
Sep 19, 2008 | Optics
Bushnell Voyager 78-4503 (675 x 20mm) Telescope Logo
95 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
