Question about Acer Aspire One Netbook 8.9" Notebook
My netbook will not charge. I have had it for less than a year. Will not power up at all. I'm thinking maybe a new battery.
    Scholar:
  • 61 Answers
It's a hardware problem of some sort but it could be the battery, the charger, or the input on the netbook itself. Trying a new battery or a new charger might work but you probably need to take the netbook into a shop to have someone troubleshoot the problem. Or if it's still under warranty since it's been less than a year, call Acer support and see if they will fix it for free.
Posted on Apr 06, 2011
  • 784 Answers
Before buying a new battery and borrow from someone like the battery charger. Try either the battery is charging. or a second battery. You can find out whether an error loading chip are faulty or defective battery or battery charger.
Packard bell netbook nav50 battery stopped charging properly. bought a new charger and battery and it still wont charge it up.
LOL, I didn't know Packard Bell was still making computers. I would think they sold you a bad battery. I've purchased new batteries before that would not charge.
Apr 04, 2012 | Computers & Internet
Basically my samsung n145 netbook wont power up unless its connected to the power supply and also i cant disconnect the power supply when fully charged as it cuts the laptop off straight away :( cheers
Replace your battery to solve this trouble.
Get a battery from a FixYa.com advertiser or anywhere computer batteries are sold.
Thanks for your question @ FixYa.com
Jul 28, 2011 | Samsung N145-JP01US Netbook
My asus 100p netbook is not charging. its only 2 months old and now when i plugged the adapter its is lighting but the battery indicator is not lighting. i am running low in battery now.
First of all, you need to make sure your power adapter is providing enough power to both run the netbook & charge the battery. A very good way to do this is to compare your netbook voltage & ampere requirements (written on a sticker on the bottom of the netbook ) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the netbook's voltage rating. Amperage of the power adapter should be at least equal to or greater than the netbook's rating. It should never be less than the netbook's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the netbook, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the netbook & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another netbook, or try a good or new battery in your netbook.
If this did not work, there might be a possibility that the charging circuitry on the netbook's motherboard is defective & needs servicing. In order to do this, the netbook needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the netbook's motherboard altogether.
Oct 09, 2010 | Computers & Internet
The netbook was perfectly working and I turned it off. normally, and now it does not turn on. I removed the battery for 1 hour and situation remains unchanged. Please inform me with someone has already...
First, you need to make sure your power adapter is providing enough power to both run the netbook & charge the battery. A very good way to do this is to compare your netbook voltage & ampere requirements (written on a sticker on the bottom of the netbook ) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the netbook's voltage rating. Amperage of the power adapter should be at least equal to or greater than the netbook's rating. It should never be less than the netbook's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 05, 2010 | Dell Inspiron Mini 10 Netbook
My netbook power cord is no longer working. the netbook charges fine on my labtop cord. will this cause any problems to the netbook?
Not at all. Especially if the power adapter is providing enough power to both run the netbook & charge the battery. A very good way to do this is to compare your netbook voltage & ampere requirements (written on a sticker on the bottom of the netbook) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the netbook's voltage rating. Amperage of the power adapter should be at least equal to or greater than the netbook's rating. It should never be less than the netbook's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Aug 24, 2010 | Toshiba Computers & Internet
Acer Aspire One battery not charging
your probably going to need a new battery
Mar 25, 2010 | Acer Aspire One AOA150-1784 Netbook
Acer aspire one D150-1Bw battery not charging
the battery is gone dude. This year manufactures have reduced the quality of batteries drastically to cut down the costs and i think u got even the worst of them.
and whats more they they dont even give warranty on batteries for more than 6 months.
so U'll have to get new one. Sorry
Jan 05, 2010 | Acer Aspire One PC Notebook
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Power problem
You have a faulty battery (worn out), this a common problem on laptop batteries, especially when it is a few years old.
You need to purchase a new one.
Feb 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Battery: Fast Discharge, Slow Charge, Charging Lights Flicker, Runs off battery when plugged in
Problems sounds like a damaged power pin from pulling or jerking on the AC cable. I use a Cable Retention Device like the one in this video to keep from hurting the pin.
Dec 29, 2007 | Toshiba Satellite M35X-S149 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
